Non-Load Equalizing trailer towing? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-29-2012, 09:01 AM
bmexline bmexline is offline
bmexline is starting off with a positive reputation.
2011 F-350 6.7 Crew cab, long bed 4x4. 3.55gears 20" Lariat rims.
I have towed a lot of trailers my entire life including my 43' fifth wheel and 36' gooseneck tandem axle dually flat trailer.
My friend had a 11,300lb (total weight of trailer and cargo) trailer he needed moved about 50 miles with a pintle tongue on it. Not having a pintle mount, he said I could borrow his. It is a 2 inch mount which means I would need to use my adapter to allow it to fit my 2 1/2 factory hitch. Being extremely safety conscious, I checked the tag on my Ford Factory Class V hitch. It says that, without load equalizing, I can only tow 6000lbs so I didn't tow it for him. I went and got my flat trailer, moved the cargo to it and took the stuff where it needed to go.
What the hell?? How can that be right? I have started researching and can't get a credible answer so I'm looking for some opinions.
I understand that most 2" ball mounts have a 5000# or 6000# capacity on them and most 1" shank ***** have the same limitation. So even if I bought a 2 1/2 inch ball mount rated at 14,000lbs with a 1 1/4 shank ball rated at 12,500lbs if the trailer doesn't have load equalizing then I still can't tow it with my 1 ton diesel?
I just can't wrap my arms around that. Can someone clear this up for me please?
Old 11-29-2012, 10:37 AM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
a weight distributing hitch distributes the load to the front of the hitch.
this puts the same force load on twice as much mounting hardware.
Did you notice that the draw rating was 10x the vertical rating? that comes from the 10% rule.
1,400# is a lot of tongue weight for a conventional pull trailer. As such, it will destroy your handling and braking.
1 1/2 Ball Hitch: Options? Twilight Fenrir Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 22 10-25-2013 06:11 PM
Towing Checklist hasteranger Excursion - King of SUVs 5 04-17-2012 11:32 PM
Pintle Ball Combo jmombo1321 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 1 07-15-2007 06:58 PM
Towing ULTRATEC 1999 to 2016 Super Duty 11 09-19-2005 05:44 AM
Do they make 12,000# 2X2 inch ball mounts? afinepoint Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 15 04-21-2005 11:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
