Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-28-2012, 08:44 PM
Sherbo's Avatar
Sherbo Sherbo is offline
1953 Ford F-100
Sherbo is starting off with a positive reputation.
1950 flathead crankshaft bolt
I have a 50 flathead that I'm trying to turnover by hand to make sure it isn't stuck. I don't have the crankshaft bolt and I am hoping someone knows the correct bolt size and thread.
Thanks all.
__________________
John
Need: stock speaker cover for 53 F100, crankshaft pulley for a 50 flathead, heater assembly (stock)
  #2 (permalink)
Old 11-28-2012, 11:29 PM
fixnair's Avatar
fixnair fixnair is offline
Garage is empty, add now
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
fixnair
I'll measure mine tomorrow but IIRC it is 5/8-18 X 1 1/2"
Yes it is 5/8"-18 NF and 1 1/2" May be a little long. Mine is 1" but that is a little short.
__________________
2002 F350 7.3 Ltr. 6sp.DRW 270K miles, 13' service body
1952 F1 flathead Project Truck
2008 Lincoln MKX
need thermostat housing & cab 4 project
  #3 (permalink)
Old 11-29-2012, 05:00 PM
Sherbo's Avatar
1953 Ford F-100
Perfect! Thanks fixnair! I got a 1 1/4 length, although not quite sure if it is correct as I still need to locate a pulley. Used a nut as a spacer and got the thing to turn over, so glad to know it isn't stuck. Now just a sticky valve to fix and i should be good!
Pain to find the bolt... went to 4 different places before finding the single bolt to buy. Without you taking the time to check yours I never would've found it as I wouldn't have known exactly what I was looking for. So happy there are people like you on this forum! Thanks again.
__________________
John
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
