96 7.3 diesel starting problems - Ford Truck Enthusiasts Forums
Old 11-28-2012, 05:11 PM
D4wheeler3 D4wheeler3 is offline
D4wheeler3 is starting off with a positive reputation.
Alright guys new member so take it easy on me but im at wits end with this. My trucks not starting again. It cranks and will jump like it wants to start but nothing anymore. Last year I replaced both batteries, Starter, Glow plug wires(valve cover gasquets), starter relay, and glow plug relay. I have done regular oil changes and change my fuel filter every oil change. I changed the oil last month as needed as well as the glow plugs. As its been getting cold the trucks been taking forever to start doing many many key cycles and alot of cranking. So thats when I changed my glow plugs and it didnt seem to help. Then I searched for possible problems on the forums and saw alot of people saying CPS because I was having very speratic start stop issues but then it went away. I changed that yesterday but I had the truck plugged in all day and batteries on the charger. So it fired right up and sounded great. It will start ok if I have it plugged in all night but then when Im parked at work all day then it wont start. I tryed to start it today but nothing, just cranks. I put a screwdriver across the glow plug relay to test it but then tried starting it and it sounded like to bears wrestling under my hood (and not in a good way) It was trying to start but sounded terrible. Im lost guys and want my truck back. sorry for the long long message just wanted to make sure I supplied enough info. PLEASE HELP!!!
Old 11-28-2012, 05:16 PM
Red97350 Red97350 is offline
Red97350 is gaining momentum as a positive member of FTE.
I would check your glow plug relay. What kind did you put in when you changed it? Check both posts on your gpr after you turn the key on. One is always hot and the other is powered by the pcm after you turn the key on. You want to see battery voltage on both of those terminals.
Red
Old 11-28-2012, 07:18 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Jumping the GPR
Quote:
Jumping the GPR takes that out of the equation . Without additional data I would guess you have a poppet issue . How many miles on the injectors ?...
You can pull the valve covers & inspect the injector spill spouts when cold ..
Old 11-28-2012, 07:21 PM
Old 11-28-2012, 08:48 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
I'm with Rick. Sounds like worn injectors. You can check this with a feeler gauge
Old 11-29-2012, 11:50 AM
I bought the truck at 250,000 miles and its at 302,000 now. Im not sure how many miles are on the injectors? How long of a project is it to change the injectors? Where should I get them from?
Old 11-29-2012, 12:06 PM
Awitte58's Avatar
Awitte58 Awitte58 is offline
Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.
Assuming the POs were like most people if something goes wrong injector wise they seem to just replace the bad ones with remans or new. Everyone is different, but I would assume some or all could be original.
Jim @ Rosewood diesel shop is the man for injectors IMHO.
He is a sponsor of our forum and at the top right of the thread above the "Rate Thread" option and below the "log out" option you will see a link you can click.
Old 11-30-2012, 05:40 PM
How exactly would u check them with a feeler gauge? what spec should they be at?
Old 11-30-2012, 06:29 PM
fordpride's Avatar
Pull the solenoid off the too of the injector and you'll see a square plate(armature plate) and see if you can get a .002 gauge under the armature plate.
A new inject has .004 .002 is the end of its life.
Old 11-30-2012, 07:05 PM
http://www.dieselpro.ca/Poppet%20Valve.pdf.................................
Old 11-30-2012, 09:35 PM
Thanks Rick for the reading, very informational.
Red
Glow plug problem need help! Metz12345 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 01-19-2015 06:48 AM
Intermittently not starting? glockholiday 1999 - 2003 7.3L Power Stroke Diesel 16 08-11-2014 10:30 AM
1991 7.3 IDI non turbo wth Banks wagners 1987 - 1996 F150 & Larger F-Series Trucks 8 10-09-2012 08:11 AM
Need some help, truck is in bad shape whitesdford 1999 - 2003 7.3L Power Stroke Diesel 16 09-27-2009 11:03 AM
Brrr... Please start! BenRosey 1999 - 2003 7.3L Power Stroke Diesel 26 01-12-2004 03:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
