6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
help translate this oasis report.....
Old 11-28-2012, 02:29 PM
redz284u's Avatar
redz284u
redz284u is offline
im looking to buy my first diesel. please help me translate this oasis report. is it a bad truck??? i see alot of what seems major work done.
https://www.ford-trucks.com/forums/p...ctureid=116227
https://www.ford-trucks.com/forums/p...ctureid=116234
Old 11-28-2012, 04:55 PM
senix's Avatar
senix
senix is offline
Received 1,407 Likes on 1,003 Posts
I can't read it worth a darn.
Old 11-28-2012, 08:40 PM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
I couldn't read it very well but it seems that part of the report is missing. They tried to do a cab off and the tech said 3 bolts broke off, then when he got the cab off three bolts broke in the turbo. Then he says something about going to straight time and the thing just ends in mid sentence. The interesting term on the report is CUDL: "this vehicle has a closed CUDL contact". What the heck is that?
Old 11-28-2012, 08:44 PM
senix's Avatar
senix
senix is offline
CUDL is a term for when the customer calls Ford Customer Service.
Old 11-28-2012, 09:20 PM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
IDK, I usd a magnifying glass to read it and still can't get all the words. Seems they were doing a cab off to rebuild the engine and had some bolt issues then "re assembled and" and then it just stops. Where is this truck, I'd wonder about three bolts breaking in the cab off and then three more on the turbo. Was this truck under water or what. i mean it's only 5 years old the bolts shouldn't be frozen like that.
Old 11-29-2012, 07:25 AM
vloney's Avatar
vloney
vloney is offline
The cab bolts are heavily coated with locktite. There are "cage nuts" on top that are easy to break loose. When this happens, you have to access the nut, whether it be under the carpet or behind the rear seat.
Old 11-29-2012, 01:01 PM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
OK, that makes sense, the tech on there said the cab bolts were "frozen", I guess that's what he meant, then he said 3 turbo bolts were snapped off and he drilled and tapped. At least that's what I think he said. Are the turbo bolts prone to berak off? just seems strange to me but then I have zero experence removing 6.4L turbos or cabs.
Old 11-29-2012, 02:21 PM
vloney's Avatar
vloney
vloney is offline
There's 6 bolts holding the pipes to the turbo. It'll be those. I've used heat many times to get those loose.
Old 11-29-2012, 03:03 PM
RM2738's Avatar
RM2738
RM2738 is offline
I can't make out much either.
Old 11-29-2012, 03:13 PM
senix's Avatar
senix
senix is offline
Interesting the op has not returned
Old 11-29-2012, 03:19 PM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
Yeah, wonder if he bought the truck?
Old 11-29-2012, 03:53 PM
redz284u's Avatar
redz284u
redz284u is offline
whats a op????? Does anybody know if the 08 f450 needs to have a DPF in california....the dealer is telling me it doesnt have it and it doenst need it.
Old 11-29-2012, 04:20 PM
slowmans's Avatar
slowmans
slowmans is offline
Op= original poster (you) yes it needs a DPF, especially in Kalifornia
Old 11-29-2012, 04:41 PM
redz284u's Avatar
redz284u
redz284u is offline
hahaha....dont i feel dumb.....no im here....just been super busy fighting with these people from the dealer. this is making my f450 experience a pita....
the truck has no DPF and no cats.....they swear up and down i dont need them cause law went into effect 2008. the truck was being built in 2006.5-2007. how could it.....but i have my local dealer telling me i need it.
i think its time to just walk away.....but i so so like the truck....but no reason to buy a headache
Old 11-29-2012, 04:48 PM
senix's Avatar
senix
senix is offline
Model year 2008..needs...is required to have the emissions stuff. Them selling it without is illegal...Tell CARB about the truck...
Quick Reply: help translate this oasis report.....
