Aux. Fuel tanks - Ford Truck Enthusiasts Forums
Aux. Fuel tanks
Old 11-28-2012, 12:05 PM
Country_boy_2007's Avatar
Country_boy_2007 Country_boy_2007 is offline
Country_boy_2007 is gaining momentum as a positive member of FTE.
Aux. Fuel tanks
I am thinking of putting an Aux fuel tank inn the bed of my truck. id like to set it up to gravity feed the front tank. i was wondering what you guys are running.
Old 11-28-2012, 07:30 PM
1989f250IDI's Avatar
1989f250IDI 1989f250IDI is offline
1989f250IDI is starting off with a positive reputation.
Just do exactly as you have stated. Plum your auxiliary tank into your existing one. As far as what we are running dont worry about it. Most are using the stock tank. Just get what you can afford and ones size that will fit your needs and bed and bolt it down
Old 11-29-2012, 01:37 AM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
do you already have factory dual tanks? if not, that would be a cheap place to start with junkyard parts.
regardless of what you have there, i fear that a straight gravity system would result in fuel overflowing out the factory tank's filler and/or vent, so i think you would want to have some kind of valve on there to only transfer when needed, probably manually
Old 11-29-2012, 06:07 AM
Otahyoni's Avatar
Otahyoni Otahyoni is offline
Otahyoni has a good reputation on FTE.Otahyoni has a good reputation on FTE.
Don't use diaphragm type electric valves if you're leaning towards electric valves. My buddy found out the hard way that 150+ gallons of fuel above one of those valves will keep it from closing.
The fuel was pushing past the valve and the Facet pump and overflowing his factory tank.
Make sure you use a ball valve or some other positive shutoff valve. I'm not sure if drawing from the top would cure that problem or not....
Fuel gauge Dcwhite232 1973 - 1979 F-100 & Larger F-Series Trucks 13 10-15-2014 03:06 PM
78 F150 Aux fuel tank issues mrlightrail 1973 - 1979 F-100 & Larger F-Series Trucks 6 01-20-2014 09:15 PM
aux fuel tank dimensions abyars111 1967 - 1972 F-100 & Larger F-Series Trucks 15 09-28-2013 04:16 PM
Fuel Tank Install Question old blue beast 1973 - 1979 F-100 & Larger F-Series Trucks 8 07-27-2013 09:04 PM
12 v fuel valve for aux. tank concordpete 6.0L Power Stroke Diesel 3 02-15-2007 10:23 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
