dual tanks - Ford Truck Enthusiasts Forums
dual tanks
Old 11-27-2012, 07:36 PM
nesport nesport is offline
nesport is starting off with a positive reputation.
dual tanks
I've seen all the posts about the Titan larger tanks, which seem to be the way to go and was ready to order, but I noticed somewhere that there is a Ford option for dual tanks (selector switch in the cab). Does anyone know anything about these? Do they have to be ordered with the truck, or can it be added after? Looked like there was a tank for and aft of the rear axle. Thanks.
Old 11-27-2012, 07:43 PM
mhoefer's Avatar
mhoefer mhoefer is offline
mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.
Cab and chassis only. We all wish.
Old 11-28-2012, 05:27 AM
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
I have a transfer flow 50 gal tank in the bed. I like their system a lot. Look it up.
Old 11-28-2012, 09:01 AM
majkthreads's Avatar
majkthreads majkthreads is offline
majkthreads is gaining momentum as a positive member of FTE.majkthreads is gaining momentum as a positive member of FTE.
Quote:
Did you look at their 75 gallon tank at all? I was trying to find out if it would fit in the bed but still let me close my bak-flip F1 bed cover.
They said no but their dimmensions look likt it might just slip under there.
Also where did you mount their fuel delivery hardware, just in the corner of the dash where most tuners and stuff are?
Old 11-28-2012, 09:58 AM
ruschejj's Avatar
I mounted the trax screen thing where you describe. Against the a pillar on top of the dash right above the driver side a/c vent. When I park in a hotel lot or something I put a baseball cap over it.
I did not look at the 75 gallon tank. The 50 I have I bought off Craig's list here where I live. Paid $400 for it. Still expensive but half of what a new one would be! I did not even know transfer flow existed until I saw the classified ad for it. Looked it up and decided to try it. I really like the trax transfer system. It just gradually pumps fuel as the main tank is drained, doing a good job of keeping the dash fuel gauge accurate considering the sum of 76 gallons. When my dash gauge says 1/2, I actually have 38 gallons of fuel on board.
Old 11-28-2012, 05:41 PM
i was afraid that the dual tanks were cab and cahssis only. I like the xfer flow, but can't give up the bed space. Guess it's off to Titan we go. Thanks for the help.
Old 11-28-2012, 11:01 PM
jcain jcain is offline
jcain is starting off with a positive reputation.
titan makes a midship tank replacement in 50gals. i have one on the way.
Fuel pump for metal rear tank Pjames 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 02-27-2016 11:33 AM
Couple dual tank issues Iantiler Fuel Injection, Carburetion & Fuel System 17 02-08-2014 01:30 AM
94 f250 dual tank wiring diagram needed? mike 96 ws6 1987 - 1996 F150 & Larger F-Series Trucks 3 08-17-2011 04:03 AM
Fuel Tank Padding linckeil 1987 - 1996 F150 & Larger F-Series Trucks 10 08-27-2010 01:24 PM
Dual Fuel Tank problem oak73 1987 - 1996 F150 & Larger F-Series Trucks 4 12-05-2006 05:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
