Is the Cowl panel off a 85-86 a direct fit on a 82? - Ford Truck Enthusiasts Forums
Old 11-27-2012, 06:53 PM
CountryBumkin's Avatar
CountryBumkin CountryBumkin is offline
CountryBumkin has a good reputation on FTE.CountryBumkin has a good reputation on FTE.CountryBumkin has a good reputation on FTE.
I am going to have my hood and cowling repainted. I'm wondering if the cowling style with the holes (rather the slots like I have now) is a direct/exact fit on my 82.
I belive the cowling with the holes came out in 85 as an upgraded design (less junk like pine needles, etc., get past the holes).
Also, i don't remember now, but can I get the cowling off (after hood removal) without removing the chrome trim around the windshield?
Does the cowling just slip under the windshield trim or does it interlock somehow?
Thanks.
Old 11-27-2012, 07:28 PM
81ChopTop's Avatar
81ChopTop 81ChopTop is offline
81ChopTop has a very good reputation on FTE.81ChopTop has a very good reputation on FTE.81ChopTop has a very good reputation on FTE.
The cowl with the small holes started in '87. Yes, they will fit, just bolt on. You should be able to remove the cowl without removing the windshield trim. The trim just holds down the rear edge of the cowl. It is better to remove the lower trim though.
My '86 is about to get one too, I'm getting tired of leaves in the blower housing.
Old 11-27-2012, 09:27 PM
bigbrown84truck bigbrown84truck is offline
bigbrown84truck is starting off with a positive reputation.
i put one from a 91 on my 84 and it is bolt up, 80-96 will all bolt up, the holes started in 87. i did not remove my windshield trim, i took all the bolts out first then sliding the cowl forward with the hood about 3/4 open. this allowed me to clear the trim and the hood and hinges. i then slid the new one under the trim then bolted it down. the hardest part is not messing up the antenna and antenna wire.
Old 11-27-2012, 10:02 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
No, only the 80 to 91 cowls will fit, in 92 and on the cowl will not fit correctly and will not match up with the hood. I found out the hard way.......
Old 11-28-2012, 04:38 AM
Excellent. I'll do a parts search for a 87 to 90 Cowl.
If someone could be so kind as to provided the OEM part number - I would be very appeciative. I only have the parts book for 1980-86.
Old 11-28-2012, 12:22 PM
Fordzilla80's Avatar
Fordzilla80 Fordzilla80 is offline
Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.
Just go out to the junkyard and find any 1987-1991 Truck or Bronco. If the cowl panel is in good shape, grab it, strip it, and repaint it.
FWIW, swapping to the newer cowl panel was one of the most effective modifications I made to my truck.
Keep in mind that leaves can and will still get through around the windshield wiper studs, however the amount of leaves getting into the cowl is reduced by at least 70%.
Water under the dash, rusted cowl or? cadunkle 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 12-23-2013 08:21 AM
87-91 cowl in 80-86? kickingber 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 04-06-2013 07:16 PM
replaced windshield and now have torn weather seals 86paGT 2004 - 2008 F150 6 08-08-2012 12:12 PM
1986 Ford Ranger Cowl attachement mike manglos Ranger & B-Series 1 03-13-2012 10:49 AM
Hood Cowl Panel Removal HD 1987 - 1996 F150 & Larger F-Series Trucks 5 06-01-2005 06:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
