300...maybe 350. If I am towing and just re-fueling I dont shut it down. Even if the EGT's are down it is way to hot under that hood.
Oh heck yeah, hard on electronics too I imagine.
I wish there was an electrical assist to the thermostat, so if you were pulling in to park, you could adjust the thermostat temp by 50 degrees or so on the last couple hundred feet before hand.
When towing cross country in the dead of summer even the outside of the fenders would burn your hand to the touch.
I don't think the 6.4 requires too much of a cool down. The EGT's should drop enough when pulling off a highway and driving rural roads. Now if you pull directly off the freeway with high EGT's and pull right into a motel or truck stop, I'd say <300 degrees and you'll be fine.
