88 f150 302 rebuild question.
Old 11-27-2012, 04:07 PM
88ford523's Avatar
88ford523
88ford523 is offline
I've been looking around on here and still have not found an answer. I'm just looking for someone that has actually put the comp 31-255-5 cam in their truck and can give me more than the cam specs. has anyone used this cam? if so do you recommend it? any issues? I'm building this engine on a budget and don't want to get a cam that won't work for me. I've done my research about the SD engine and all that stuff. Just looking for a real life use of this cam. thank you.
Old 11-27-2012, 04:43 PM
Nally427's Avatar
Nally427
Nally427 is offline
I have this in my 5.0 and its great. I had to adjust the timing to really get it tuned in but after that, its great. Starts right up, good idle, and my engine now easily revs past 4 grand and it pulls alot harder than the tiny stock one. The lift with stock rockers is .464 intake .474 exhaust.
Old 11-27-2012, 04:46 PM
88ford523's Avatar
88ford523
Thank you so much. I saw one of your posts about putting it in but nothing about how well it worked. again thank you for your response.
Old 11-27-2012, 04:50 PM
Nally427's Avatar
Nally427
Nally427 is offline
No problem, just make sure you install new lifters and timing chain with this cam, and for a little more punch put a set of 1.7 rocker arms on. I did and noticed even more pulling power. And it gets the lift closer to .500
AZTrooper
01-05-2018 06:46 AM
outdoorfan
13
11-14-2013 08:13 PM
smolicht
19
12-17-2004 08:57 AM
Steve_B
Flathead V8 & Flathead 6
05-30-2004 09:36 PM
1988ford
02-19-2003 07:05 PM
Quick Reply: 88 f150 302 rebuild question.
