Help! My coolant leaks out right after I put it in!
I know that it is not my engine! It was running great prior to this. I have a 6.0 2004 F250 Deisel. I have changed glow plugs, injectors, oil cooler, wiring harness and more. Now my coolant leaks out somewhere near the top of my engine. I am no expert. But does it sound like a bad water pump? I am hoping. I am at my wits end. I am being forced to sell my beautiful truck. But I need to fix this problem first. Please help!!!!
There are no signs of water in the oil or oil in the coolant. And it is not leaking from the radiator. Does this sound like a bad water pump?
Blue hose in this picture:
There is also a very large o-ring between the intake manifold and th front cover. Not a great picture here but you can see where it goes. In the round recessed area at the edge of the bottom of the picture.
Most of the other leak areas you can see pretty easy these two can be hard to get a bead on because they're kind of hidden.
I had a coolant leak too after oil cooler and egr cooler replacement. I have included a link to my posts and replys
https://www.ford-trucks.com/forums/1...eartbreak.html
the fourth post down by m-chan68 saved my bacon. Hoping your repair will be as simple.
CHECK THE HEATER HOSE THAT RUNS OVER THE FICM, I JUST HAD TO REPAIR MINE, I found out 05-06 they've had an issue
I just did my heater hose in the same area, right at the back corner of the FICM. Cut about a half inch out and used a hose kit from Autozone after looking at all of the hardware stores for a 3/4" barbed hose coupler. Good times.
Daddy kitty and Nice pics Rusty for the top side leak, also heater core and there was a tread on the vaccume dont know what its called by the heater core it leaks out of the screw on the top.the heater hose by the ficm I tied that hose back off the ficm bolt .are you seeing coolent on any one side besides the top on motor?
sullyt28
02-05-2019 10:01 PM
6.0owner
03-19-2016 11:03 AM
Bowtie_Schmowtie
09-28-2009 03:47 PM
