code 173?
Old 08-29-2002, 07:22 AM
bcj6402's Avatar
bcj6402
bcj6402 is offline
code 173?
could someone tell me what is/what causes a code 173 "HEGO SENSOR FAULT - RICH"?
thanks
brian
Old 08-29-2002, 09:39 AM
gasman6674's Avatar
gasman6674
gasman6674 is offline
code 173?
Vacumn leak, Bad sensor. The sensor is reading rich and the computer can not adjust the air/fuel enough to change it so it throws a code.
Do you have any runability problems? O2 sensor is not real $ so if its original and you have a few miles on it I would start there.
Regards
Gasman
Old 08-29-2002, 09:54 AM
wbw189's Avatar
wbw189
wbw189 is offline
code 173?
Hey Brian,
I pulled a code 172 "HEGO SENSOR FAULT - LEAN" on my '94 F150 302.
After checking the wire harness, I found a corroded lead right at the O2 sensor. I picked up a new sensor for about $40 and haven't had a problem since. Clear the codes and if it reappears you might want to look into a new sensor.
Good Luck,
Ben
Old 08-29-2002, 09:58 AM
bcj6402's Avatar
bcj6402
bcj6402 is offline
code 173?
ben-
actually, right before this happened i was changing out my starter and i know i hit the harness for the o2 sensor several times with my ratchet and i was moving it all around to get the starter up and down. i was thinking that it may just be a connection. i'll check that out. thanks
brian
Old 08-29-2002, 01:09 PM
honney's Avatar
honney
honney is offline
code 173?
ingram
10-06-2017 10:05 PM
BRay09
33
02-25-2011 06:10 PM
Boss F150
07-05-2009 09:23 AM
alz
01-22-2006 01:39 PM
Wakeboarder141
34
08-04-2004 11:28 AM
Quick Reply: code 173?
