02 F250 4x4 suspension or body knock
I have a knock in my 02 when turning sometimes and when hitting some bumps in the road. It almost sounds like the rear of the driver's side FRONT leaf spring is popping. could possibly be a body mount or something...
It sounds like a clunking or popping sound...
Any tips or tricks on figuring this out?
Any common problems already discussed here that I can read up on and learn?
I to have a nasty clunk coming from that area. Sometimes when turning or hitting a bump. It doesn't have it all the time. It feels like the front suspension is actually shifting over when it happens.
The po put a small lift kit on it and I've had to change the pitman arm bc it was very very worn out. I had the wife get in the truck while I watched the steering to see if anything was moving and didn't see anything out of the ordinary.
Let me know what you find. I'll look at the sway bar like Bigpipes said. The noise/issue is very un nerving.
my truck still does this once in a while, its a solid front axle its gonna make a little noise. I installed new energy suspension sway bar bushings, new front leaf springs, check the torque on the cab mounts, new shocks, new ball joints etc etc etc. Ever once in a while its gonna make a small amount of noise, you ever drive or ride in a medium duty or larger truck? They creak and groan all the time, its doesn't mean anything is wrong with them. I sunk so much money into this turning bang i get once in a while I'm over it, i KNOW everything is brand new and replaced, i know nothing is broken or loose, i learned that i own a six thousand pound 1 ton 4x4 thats suppose to be used for work and its gonna make some noise, if i didn't need it id go buy a 2wd car!
thor363
09-14-2018 03:24 PM
