Blinkers stopped working?
Old 11-27-2012, 09:05 AM
Shanemh's Avatar
Shanemh
Shanemh is offline
I have a 96 f150 with a 5.8L V8.
My blinkers have stopped working and I have no idea why. I checked the fuses and they're fine. The 4 way flashers still work. Another thing I noticed is that it also seems that a bulb or light behind behind the instrument cluster is not working because right where my fuel level and battery level are, it's darker than it was.
Any ideas???
Old 11-27-2012, 09:35 AM
Boomer65's Avatar
Boomer65
Boomer65 is offline
just one thought..... it may not apply to your truck. I had a 68, and a 75 f-150.. both had badly worn turn signal switches. I bought an aftermarket switch first... wrong thing to do... so coughed up the money for a ford part... and wham-o ... problem solved..
Old 11-27-2012, 09:51 AM
Boomer65's Avatar
Boomer65
Boomer65 is offline
does your truck have an aftermarket plug in for trailer lights?.. I have a 75 f-250 now, and it had connection problem when I got it ...it had no signal lights... cured it but it took some crawling under the rear to check it all out.
I also had a bad brake light switch once on and older ford that caused turn signals to not work
Old 11-27-2012, 10:54 AM
Shanemh's Avatar
Shanemh
Shanemh is offline
No after market trailer lights, brake lights good too. Only thing that I notice is the instrument cluster light seems duller, like a bulb or light isn't working there. Otherwise all other lights are fine
Old 11-27-2012, 11:07 AM
DeadmanF250's Avatar
DeadmanF250
DeadmanF250 is offline
There are two separate relays...one for your hazards and one for your flashers. Just a thought if you haven't checked. Maybe swap one for the other and see if the flashers work.
bent71
Electrical Systems/Wiring
01-24-2012 07:58 PM
87Ford250
10-06-2011 08:03 PM
1974oneton
09-15-2009 06:44 PM
scottlane
21
10-04-2005 08:27 AM
jakegypsum
04-24-2001 11:34 AM
Quick Reply: Blinkers stopped working?
