How hard is it to replace ball joints on a 93 Ranger 2wd?
It's not difficult if you have the time & the right tools. And, yes, an alignment must be performed afterwards. You can borrow a ball-joint puller tool set from many auto parts stores for free. They just charge your credit card number to insure you return the tools, then cancel the charge afterwards.
If you have to replace three joints, then it's advisable to replace ALL the ball joints. The others are probably near the end of their life anyway, and this way you only need to get one alignment. Make sure you replace both ends of the tie rods, too.
This is posted in the van section:Guide To Replacing Balljoints On Ford E150 Econoline Vans .: Articles
It's basically the same thing.
Not a super difficult job, just time consuming.
Having the alingment checked is a good idea, but I did not have it done on mine. I also replaced the caliper guide pins and repacked wheel bearings while I was there.
varminthunter243
1999 to 2016 Super Duty
18
09-20-2015 12:01 PM
BombThreat
18
11-15-2013 05:21 AM
joshuaamoody
03-22-2003 10:00 PM
