Adjusting throttle cable/gas pedal pressure
Old 05-23-2003, 12:11 AM
73Galaxie's Avatar
73Galaxie
73Galaxie is offline
How do you adjust the gas pedal pressure? My gas pedal is really stiff. I've checked the cable and looked for kinks and such, even popped off the cable to see if the carb was sticking - so how do you adjust the spring that pushes the throttle connector that attaches to the carb? Do you somehow remove the spring and put on a weaker one or does it have something to do with turning the six sided metal thing that goes through the intake support? It gives my right leg a cramp after 1 hour of steady driving, so i kind of want to fix this!
Scheol
05-14-2013 05:57 PM
bruce381
1997 - 2003 F150
07-08-2011 09:15 PM
mr_ranger-79
01-17-2011 09:36 PM
mike L
07-12-2006 11:06 PM
frachubb
Bronco II
10-19-2003 08:33 PM
Quick Reply: Adjusting throttle cable/gas pedal pressure
