78 f150 460 engine cam choice
Old 11-26-2012, 06:55 PM
FORDMANMATT's Avatar
FORDMANMATT
FORDMANMATT is offline
So if I decide to stay with my D3 <NOBR>heads</NOBR> that I have done mild port work new valves and <NOBR>stock</NOBR> 22cc pistons and I go with the victor2 or rpm intake what is the biggest cam I can go with so I can race it occationally at the track and have still a nice street cruiser, and what kind of HP can I expect, also I will have 3.73 rear end c6 trans posi not sure on <NOBR>tires</NOBR> yet
Old 11-27-2012, 06:06 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
With hydraulic lifters, you can certainly cheat a little bit since they are more fogiving on valve overlap than mechanicals....if you add in variable blled lifters (made by Crower Cam or Rhodes- these are a little noisey though compared to crower which are quiet) you can even cheat with more lift. You have a heavy vehicle too...so you are going to need tq more than hp especially for the street & keeping your RPM's moderate...
I would call in general for....
290 duration & 580 lift
And remember, advertized lift/duration/lobe separation is just that- advertized and not the specific grind including ramp profile that is used on the cam. I highly recommend Iskenderian & Crower & Chet Herbert & Lunati...all are family owned, been grinding cams for decades. Especially with good machine work...up to 100 hp improvement would not be out of the question....I would swag the tq increase would be parallel as well.
Boss50
03-17-2013 09:51 PM
FORDMANMATT
11-27-2012 02:47 PM
F-250 restorer
10-05-2010 07:24 PM
460/F250
24
01-13-2009 11:13 AM
jwtaylor
08-31-2003 04:11 PM
Quick Reply: 78 f150 460 engine cam choice
