Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-26-2012, 04:08 PM
BCHauler's Avatar
BCHauler BCHauler is offline
Garage is empty, add now
BCHauler has a good reputation on FTE.BCHauler has a good reputation on FTE.
Frustrated with Scanguage II
I have had a scanguage 2 for a year or so now. I like many of the features it has like being able to monitor different guages and tracking mileage. I have recently bumped into a problem that has me quite frustrated. I'm having a bad fuel economy issue - truck is GUZZLING gas - and I've been trying to use the scanguage to help diagnose the problem. I checked the internet trying to find information on how the scanguage determines fuel economy so that I knew which sensors to explore in finding my problem. O2, MAF, etc. Finding nothing online, I called Scanguage's tech support line, explained what I was doing, and asked how they determine fuel economy so that I knew where to look. Their response was "That information is proprietary and we can't tell you."
__________________
Todd - Hockey Dad
1999 f150 sc/lb 2wd 4.2 310,000kms and counting
2001 F250 Crew 4x4 6.8 - sold
94 F150 SC 4x4 5.8 E4OD "Solid Gold" - RIP
  #2 (permalink)
Old 12-27-2012, 07:50 AM
DIYiT's Avatar
DIYiT DIYiT is offline
1995 Ford F-250
DIYiT is gaining momentum as a positive member of FTE.
I'm taking a guess here, but I believe the ScanGauge uses a combination of things:
  • The motor size you entered when you setup the ScanGauge
  • OBDII information on O2 sensor data
  • OBDII ECU data for injector pulse width
  • The correction factor you enter in when you fill the tank
At the minimum, these few items will allow the ScanGauge to estimate real-time fuel economy, but I'm not sure if it's using other information to help correct for any errors in the sensor data. I'd be interested to know what else you find.
__________________
1995 F-250 - Vortech 460, E40D - 4x4 3.55, Single Cab, Long Box
DIYiT's F-250 Build Thread
-Dana 60 Swap
-Vortech Install
  #3 (permalink)
Old 12-30-2012, 07:33 AM
itsakeeper itsakeeper is offline
itsakeeper is starting off with a positive reputation.
It should show any error codes that are recorded but other than that I don't think the scangauge will help in diagnosis - I have one on a Tacoma to track mileage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
