Door lock on 52 working correctly?
I can use my key and lock the door from the outside and also unlock it from the outside.
Problem is if I lock the passenger door from the inside by pulling the handle the key will not unlock it, leaving me locked out when I also pull the drivers door to lock it.
In other words to lock my truck and not get locked out, I pull down the drivers door to lock it, shut my passenger door and ONLY lock it with the key and then unlock it with the key.
Am I missing something in the door or is this how it should work?
I got stuck/locked out in a parking lot by just pulling back both handles and shutting the doors. I have had the truck for 11 years and never really locked it prior. I had some valueables in it this time, ie a small cooler full of beer, cell phone and my clothes for the weekend at Turkey Run.
Seems to me the only really valuable thing was the cooler full of beer, the other things you get by without!
I don't know if it was designed that way (apparently it was, thanks Doc) or if something is malfunctioning, but I learned a long time ago to always use my key to lock the door. That or admire my keys hanging from the ignition while I struggled with a coat hanger.
I don't know if it was designed that way or if something is malfunctioning, but I learned a long time ago to always use my key to lock the door. That or admire my keys hanging from the ignition while I struggled with a coat hanger.
LOL. I've always wondered if you could get a couple buddies and just shake the crap out of the truck until one of the two handles fell back down into the unlocked position. But they seem to hold pretty firmly when you put them into the locked position.
I've never really studied it carefully, but I wonder if you could remove the spring mechanism, that holds the passenger side handle in the locked position, as a method to prevent somebody from unwittingly locking that side from inside. I've had a LOT of passengers do that. In my experience, everybody wants to pull up on that handle instead of down when they exit the truck.
I agree on the shaking part, it seems that you can shake them locked or shut the door hard enough to get it to lock. Fustrating, but just a part of owning one of these!
After the driver's door was opened, I got inside, locked the door from the inside and exited through the locked passenger side door that was previously locked with a key.
I did a similar thing over the weekend. Needed to get into the 51, but the doors were locked. I remembered that the driver's side was locked from the inside but had a loose spring. I bagged on the door in the inner door handle area with the palm of my hand a few times, and voila, the door was now unlocked. My father-in-law had a puzzled look on his face when I was banging on the door, not knowing what my plan was.
That sounds a bit like a scene out of a cartoon. Did you then poke your head out of the glove box? <
So you're saying if you exit either of the doors, and push the door handle forward before closing it, it will be locked? I've never tried it that way. That doesn't seem right. I don't see how you could get a coat hanger in there either. (maybe if your division channel rubber is shot)
Ross, if I recall correctly, the door handles on your particular truck are installed differently so that your "locked" position isn't horizontal. Nevertheless, you can indeed lock either door that way, and the key is useless in that situation.
If you pull the handle up into the horizontal "locked" position on both doors and close them, your butt is locked out. I think Jolly Roger Joe was successful because his truck is currently missing its rubber. But trust me, if you're desperate enough, you can get a coat hanger around even modern weather stripping. Ask me how I know.
Thanks guys, at least I now know my locks work as Henry let them leave the factory. (what a bad design...LOL) Now days it would be a recall.
Bryan
LOL. That's a horrible feeling to be locked out of your vehicle far from home with no help. Good job!
Another thing that I've always thought about is the rear window. It pushes inward in order to remove it. Depending on how much glue, etc. you might have on the weather stripping, might be another point of entry in a pinch when all else fails...... Good thinking on the fuel filler grommet.
