Diff Question what can you tell me
Old 11-26-2012, 11:38 AM
fordf350camper's Avatar
fordf350camper
fordf350camper is offline
Hi i have looked on the Id plate on my rear axle on the 1957 ford f350 dually and this is what it says. DTA co model B100 NX1 Ratio 5 833 Serial no 014008 the question is.What is the ratio is it any good i would like more speed can i swap the diff if so what kind ratio do i need and which model ford will have one.Now with me being in the Uk i will have to have one shipped thats when i find one.Thank you.My axle does not split in half and the bit that sits on the springs is square thank you
Old 11-26-2012, 11:50 AM
fordf350camper
I have now looked in my manual and there is a picture of the axle it says its a Timken so would you have any idea which diff i can fit thanks
Old 11-26-2012, 06:06 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
I'm using a Sterling 10.25 from a '92 F350. Mine is a wide dually pickup type. You most likely need one from a cab/chassis dually, which is a bit narrower, and more common. I had to move the spring pads about 1 1/2" or so. That was easy, and I'm no pro. Now I have 4.10 gear ratio. I have gone 65 a few times with no issues. I think it used to top out around 45-50 mph.......
The following users liked this post:
Old 11-27-2012, 10:15 AM
1960fordf350's Avatar
1960fordf350
1960fordf350 is offline
timken/rockwell B100 axle. You have a 5.83 rear end. They made a 5.14 diff and also a 4.88 I had the 583 and was able to buy a 5.14 That rear axle is common in studebaker 1 tons and some dodges. International used a similar rear with the same bolt pattern for the rims, but the diff is a total different diameter. If your trying to keep the original rims, you'll have a challenge, but keep looking.
Old 11-27-2012, 11:03 AM
fordf350camper
Hi would it be better with the 4.88 diff would i have to swap the total axle or can i just swap the diff thanks
Old 11-29-2012, 09:42 AM
1960fordf350
Depends on what you find. You can pull the diff without taking the wheels off. Yank out the endshafts and then you can remove the diff. It comes out as one unit. A tranny jack or a good floor jack helps. That diff is heavy. If you can find a whole axle of the same type, you'd have some spare parts for the long run
Old 01-21-2013, 02:20 AM
iwanaflattie's Avatar
iwanaflattie
iwanaflattie is offline
Hey Guys,
I know this is an old thread but It mentions something of my interest.
I am Looking at at dTa b100 rear end(dually) With a 5.14 Ratio,I was wondering if the Gearing is to high.
I want to use it on my COE(providing I find 2 front wheels and having them fit my Front end)
engine is a late small V8 and automatic.
Thanks guys
Old 01-21-2013, 11:37 AM
1960fordf350
Depends on what you are doing. If your not worried about originality, find a newer 8 lug dually rear with a better ratio. My truck will cruise about 55 with that rear, but I'm like at 3,300 rpms. That's with 17.5 tires
Old 01-22-2013, 01:08 AM
iwanaflattie
Thanks man,I just love the look of the old wheels.
The Rear end has some 15" wheels and I was planning to use those size tires but I guess I would only be doing 40mph at 3500 with them
Old 11-02-2021, 04:15 PM
Cwillson's Avatar
Cwillson
Cwillson is offline
I need help
This is probably a shot in the dark since this is such an old thread but do you know where I could get gears for my b100 rear end the 5.83 are too high I’d like the 4.88
Old 11-02-2021, 06:16 PM
spurredon's Avatar
spurredon
spurredon is offline
Yes, you may well win the oldest post revival award but welcome to FTE. What is the year of your vehicle. All the info you provide can help you.
Old 11-02-2021, 08:31 PM
1960fordf350
4.88 gears are un-obtainium. I snagged a set of 5.14 purely by accident. I added an auxiliary overdrive box with 17% overdrive. It'll run 65, but it's wound out. If your not worried about originality, get a newer rear axle with a good ratio. Don't gear for too much speed, you'll lose top end power, especially if you pull a load behind it. Dodge and International used 6 lug rears also back then, maybe you can come across an axle from one of those. However the IH axle uses a bigger pumpkin diameter, so you need a whole axle, the gearset won't plug into your unit. Or find an Isuzu or Mitsubishi truck from the 90's They had 6 lug rears plus tubeless tires.
Old 11-18-2021, 04:31 PM
Cwillson's Avatar
Cwillson
Cwillson is offline
Thanks
Whats the bolt pattern on the timken B100Nx1?
I think since it seems parts for this rear are unobatanium. I'm going to upgrade to a newer rear end probably a sterling 10.25.
Farmtruckn
08-02-2015 12:30 PM
flainn
19
07-23-2012 06:15 AM
Cubby1986
10-10-2011 09:27 PM
crazy4Fords
11-25-2004 08:45 PM
460Brnc
10-29-2004 09:27 PM
Quick Reply: Diff Question what can you tell me
