1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
transmission temp
Old 11-26-2012, 07:50 AM
ronald48's Avatar
ronald48
ronald48 is offline
transmission temp
I have a 1999 powerstroke w/automatic tranny, My transmission temp reached 248 for a short period while pulling a trailer up a steep incline(alarm started flashing on Edge display). Once I leveled out the temp dropped back and alarm cleared. What is maximum temp and how long can a person run in alarm before damage occurs ? I have 70k miles on odometer. Is this transmission equipped with a fluid cooler ?
Old 11-26-2012, 08:00 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
250°F is Ford's limit for that transmission. If you reach that limit you should find a safe place to stop and fast idle in park or neutral. DO NOT SHUT THE ENGINE OFF WITH THE TRANS THAT HOT!
1999 trucks left the factory with one air to oil cooler for the transmission. That was soon proven to be inadequate. Mid year 2000 Ford added a second cooler inside the engine radiator. Many 1999 trucks were retrofitted with a new radiator with a cooler.
If your truck doesn't have a radiator cooler I recommend changing the radiator for one that does. Another good modification is to replace the current air to oil cooler with one from a 6.0L truck.
Old 11-26-2012, 11:55 PM
ronald48's Avatar
ronald48
ronald48 is offline
Thanks Mark, kinda figured there was an upgrade of some kind. Looks like the change to the 6.0 air to oil cooler is the cheapest option for sure. Will this do enough cooling to keep me out of alarm or should a person just spend the cash and have a new radiator installed ? Is Ford the only place to get these upgrades or is there an after market supplier of parts(will install myself), thanks again...Ron
Old 11-27-2012, 05:09 AM
Mark Kovalsky
Radiators are available anywhere that sells auto parts. Is the 6.0L cooler enough by itself? Maybe, maybe not. Did you look to see if your radiator has a cooler?
Old 11-28-2012, 11:14 PM
ronald48's Avatar
ronald48
ronald48 is offline
Thanks again Mark, my particular truck has the air/oil cooler. Ive checked with a local diesal truck performance shop and the hot hookup is the 6.0 cooler to replace my stock one. It fits where the old one sets and doubles the cooling capacity, they also mentioned a kit that changes the cooler bypass where oil doesnt bypass anymore, thus allowing more oil flow thru the cooler. Its kinda pricey but well worth it I think, thanks again !
Old 11-28-2012, 11:30 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
A 6.0 trans cooler is very cheap compared too a 2,500.00 re-build! Its cheap insurance!
Old 11-29-2012, 07:43 AM
Mark Kovalsky
Before installing a kit to replace the bypass make sure you have enough money to replace the transmission. Eliminating the bypass can destroy your transmission.
The bypass is there in case the cooler circuit gets restricted. After the ATF leaves the coolers it is returned to the rear of the transmission and used for lubrication of the rear half of the transmission. If the cooler is plugged the bypass opens and supplies the rear half with lube. If the bypass is eliminated and the cooler is restricted the first you will know about this is when the transmission self destructs.
If the cooler circuit is flowing normally 0% of the flow goes through the bypass and 100% goes through the cooler. How can you improve on that?
Encho
02-23-2013 08:28 PM
KJNDIVER
18
04-12-2012 01:19 PM
fordsgofaster
09-16-2010 07:26 AM
jav409
04-21-2007 11:53 PM
92exploder
1978 - 1996 Big Bronco
08-03-2003 02:52 PM
Quick Reply: transmission temp
