87 transmission problems
Need more info on truck.
Engine, tranny etc.
But i'm gonna take a wild guess here, you could have the 3 speed C6, and the higher RPM shifts are probably due to a bad vacuum modulator valve.
It is on the passenger side of the transmission, facing the rear, it's a lil round thing held in by an arm, with a 1/2" bolt.
There will be a vacuum line going to it, just remove the line from the modulator, if oil comes out of the line, or the modulator it self, it's bad. Replace it, and avoid driving the truck until you do replace it.
However, if your truck is an F150 (or Light duty 250) and have the AOD tranny, it might be just the TV cable out of adjustment.
Engine, tranny etc.
08-07-2016 06:35 PM
plefe
27
01-10-2015 11:40 AM
Bigruss1987
03-25-2014 07:33 PM
SnyderK4660
08-24-2013 09:40 PM
