2005 F-150 transmission fliud & filter change - Ford Truck Enthusiasts Forums
Old 11-25-2012, 10:34 PM
Coondawg Coondawg is offline
Coondawg is starting off with a positive reputation.
Hey fellas.
Can anyone tell me how much ATF I will need for a transmission fluid & filter change?
The truck is a 2005 F-150 STX 4X4 4.6L AT.
Old 12-08-2012, 08:05 PM
Well I just finished this. PITA! I will never understand why the vehicle manufacturers won't put a drain plug in a transmission pan.
Anyway, mine took 6qts of Mercon V.
Old 12-09-2012, 08:07 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
They do! They just don't put it on the trucks they sell us. The part number for the F-150 factory (OEM) XMSN pan with a drain plug is:
F8UZ-7A194-AA
You should be able to find one online for about $53.00. Some guys with welders available install their own bungs and plugs cheaper. Other guys opt for after market pans. Sorry for the late reply... I used the same amount with my pan-drop fluid change, and put on the "drain plug pan" at the same time.
I read somewhere the drain plug pans were only installed on fleet orders like U-haul or some such. If a manufacturer ever wants my opinion... If it holds fluid it should have [accessable] drain & fill plugs.
How nasty was your pan magnet?
Old 12-09-2012, 10:18 AM
Thanks for the info. Better late than never.
Old 12-09-2012, 08:45 PM
wisecountybuck wisecountybuck is offline
wisecountybuck is starting off with a positive reputation.
Be careful if you have high mileage on your tranny and have never changed the fluid. Changing can cause the tranny to start slipping...
Old 12-09-2012, 09:51 PM
93,000 miles on the clock. Interesting. Why would changing it cause it to start slipping?
Old 12-09-2012, 10:01 PM
Quote:
I'm no mechanic but have been told by tranny mechanics that it can cause them to slip if they haven't had a fluid/filter change in a long time (miles). Guessing the dirty fluid has particules in it to help the clutches hold and clean fluid would not. Call a tranny shop and ask them. That's what I did and he told me to NOT change mine and if it started have issues then bring it in early before there is much damage.
2005 ford f150 help stirling35 2004 - 2008 F150 5 06-01-2015 07:25 PM
2005 F250 Trans ?? CPB1 1999 to 2016 Super Duty 2 10-23-2013 10:57 AM
2005 f150 transmission do not go forward only reverse soto_angel 2004 - 2008 F150 7 12-10-2012 07:19 PM
2005 5.4L Oil Filter ??? n8line1978 2004 - 2008 F150 14 03-17-2012 10:53 PM
transmission oil change rileyruffen 2004 - 2008 F150 5 03-04-2011 02:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
