Vacuum to hubs in 2wd - Ford Truck Enthusiasts Forums
Old 11-25-2012, 04:45 PM
steelhead2's Avatar
steelhead2 steelhead2 is offline
steelhead2 has a good reputation on FTE.steelhead2 has a good reputation on FTE.
Ive got a small vacuum to my front hubs when in 2wd. Noticed a thump thump noise going around sharp corners like i had my hubs in. Sure enough i pulled the vacuum line off and have a vacuum there. Looked in the tech folder trying to find a vacuum schematic but couldnt. Anyone else ever had this issue?
Old 11-25-2012, 04:49 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Steel IIRC thats Normal the Vac Part
High Vac when Hub is Locked
Low Vac In Free
But always some vac
Hublock Operation
With the hublocks in the AUTO position, the 4x4 ESOF system uses timed vacuum sequences to lock and unlock the wheel ends
when switching the instrument panel MSS between 2WD and 4x4 modes. A high vacuum level (222 mm [8.75 in] Hg and greater) is
applied to the hublocks to lock the internal spring mechanism that engages (locks) the hublocks for 4x4 mode, and a lower vacuum
level (114 to 184 mm [5.9 to 7.1 in] Hg) is applied to unlock the spring mechanism that disengages (unlocks) the hublocks for 2WD
mode. The vacuum signals are supplied to the hublocks by system components, including the 4WD control module or GEM,
wiring
harness
, solenoid, vacuum harness and vacuum seals. As a first step in service, eliminate obvious items such as loose wiring
connections, loose vacuum connections or damaged vacuum lines.
Hublock Engagement/Disengagement Time
With the hublock dials in the AUTO position, switching the instrument panel MSS to 4x4 HIGH or 4x4 LOW results in the high
vacuum level being applied to the hublocks, which lasts for at least 51 seconds (including a venting cycle). The hublocks should
engage during this time through the spring mechanism. Switching the MSS to 4x2 less than 51 seconds after the MSS has been
switched to 4x4 HIGH or 4x4 LOW will not interrupt the high vacuum level; instead, the lower vacuum level will be applied after the
high vacuum level cycle is completed.
With the hublock dials in the AUTO position, switching the MSS to 2WD results in the lower vacuum level being applied to the
hublocks, which lasts for about 15 seconds. However, the actual time required for the hublocks to disengage by spring force can
vary considerably due to the effects of driveline wind-up. Road bumps, vehicle speed, acceleration cycles or momentary reversal of
direction can assist this process. Switching the MSS to 4x4 HIGH or 4x4 LOW always overrides the lower vacuum level cycle and
results in an immediate high vacuum level and in locking of the hublocks.
Old 11-25-2012, 05:09 PM
steelhead2's Avatar
Thanks benny. Wonder if my springs are getting weak. It thumps in both right and left turns. Ill pull the hubs off and take a look.
Old 11-25-2012, 05:16 PM
BLADE35's Avatar
is the Axel catching and Locking in when it shouldnt be???? the hub may need to be taken apart and greased if so
Have you checked Ball-Joints and U-Joints and shock mounts ect.........
Old 11-25-2012, 05:26 PM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
There should be NO vacuum to the hubs, except for the timed pulse after switching into and out of 4WD. The high vacuum is applied to lock the hubs, then it is released. The low vacuum is applied to unlock them, then it is released. If it isn't released, they are going to try to pull in.
If you are measuring vacuum there, then your PVH solenoid is probably leaking and needs replaced.
Old 11-25-2012, 05:34 PM
BLADE35's Avatar
Yep Dave is right
Looks like vac is engauged for 51 seconds to engauge hub
and 15 seconds to Disengauge Hub
Did my Post look framiliar Dave????? It was yours
Been a Few since I have seen you here good to see you come back
Old 11-25-2012, 11:10 PM
87crewdually's Avatar
87crewdually 87crewdually is online now
87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all
Based on my experiences with auto locking hubs, one of the failures for inoperable hubs is the axle seal. If you had ball joints or hub bearing assembly work, there's a good chance the seal was not replaced and is damaged. The locking hubs themselves don't require alot of grease and too much grease can actually cause issues.
To test, apply vacuum at the fitting on the steering knuckle and it should hold vacuum. If it immediatly loses vacuum, chances are the seal is bad or the oring around the hub.
I did have one truck with a vacuum pump failure once.
clunking in 4WD pgguru Excursion - King of SUVs 3 12-11-2014 02:00 PM
Question about pulling the auto locking hubs kissfan79 Excursion - King of SUVs 16 11-18-2013 09:41 AM
Hubs will not unlock in 2wd please help theduke308 2004 - 2008 F150 3 02-04-2012 08:09 AM
Is this the Auto Hubs or Transfer Case? SuperBeast460 1987 - 1996 F150 & Larger F-Series Trucks 10 04-06-2005 12:08 AM
Thump?? TomB 1999 to 2016 Super Duty 16 06-04-2003 08:25 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
