Remove front passenger axle shaft 1993 F150 4X4
I am trying to replace the ball joints on a 1993 F150 4X4, but I can not get the passenger side axle shaft out. Any one know if there is a clip that has to be removed or some other trick? The drivers side slipped out without a problem, but the passenger side will not budge.
Thanks
John
Thanks
John
https://www.ford-trucks.com/forums/9...-u-joints.html Here is a link to a good writeup on that job.
If just doing ball joints then look for the rubber boot over the third universal joint in that axle shaft, remove the boot clamp and seperate the axle shaft at the joint (outer piece of axle shaft will pull straight out).
Moto52
16
07-19-2017 05:26 PM
bmacky14
03-24-2013 07:11 PM
