problem with 4WD on 2004 F150 FX4
This link will probably answer everything you need to know.
https://www.ford-trucks.com/forums/8...then-some.html
JFYI.....if you need the hub actuators, they are $62 on Amazon....same mfr and appear identical to the $120 and $180 units. The Solenoid I would go Motorcraft as well as the the check valves. Keep in mind if the actuators are worn down from grinding, there is something in the vacuum system that caused it so its important to find the cause before ruining the new actuator. I learned the hard way.
JRROTH1
04-05-2010 09:11 AM
