2012 Explorer's Sync - Ford Truck Enthusiasts Forums
2011 & Newer Explorer Discuss the all new redesigned Ford Explorer
Old 11-25-2012, 10:18 AM
montey2005 montey2005 is offline
montey2005 is gaining momentum as a positive member of FTE.montey2005 is gaining momentum as a positive member of FTE.
I don't get a chance to drive the wife's vehicle but when I do I start fiddling with the Sync system and have come to realize that it plainly just SUCKS! All those who have said fire everyone involved with it is dead on. I'm really getting annoyed to the point that I might convince my wife to sell the thing and go back to Benz. We have no "call" commands that work and no bluetooth player connectivity or controls and those are just two problems. Has anyone updated their software and gotten back such controls? We did not pay this premium for a half *** system. Your input would be greatly appreciated.
Thanks.
Old 11-25-2012, 07:43 PM
Jam3z Jam3z is offline
Jam3z is starting off with a positive reputation.
Montey it sounds like you have a problem that the dealer needs to fix. My 2012 has had and still has clunky software and occasional glitches but the phone has always worked. If you have no bluetooth that might explain why the phone won't function since it uses that connection. That could be either a hardware or software problem.
You can eleminate the software problem by first trying a "master reset." It is found in the system menu. Probably easier if you go by the steps in your owners manual as nothing is intuitive about sync. That will reload your software. If that does not change anything you might try downloading the latest update from the syncmyride website. That too is not easy but can be done if you give it several tries. Then install the update in your Explorer. That part works pretty well. The update reinstalls the whole system so anything bad in your current software should be replaced.
If the updated software does not change anything for you then you have a hardware problem.
I hope that you are still under warranty.
My dealer offered to install the last two updates for me. I declined but had so much trouble with the last one that I will probably let them do the next one. Calling the support phone number was no help at all. They said my computer was not set right and they would not help with that. I used the dealer's computer and had the same trouble. Good thing that it did not download for a few days since they put a bad version of the update on their website and everyone that installed it had problems which they could only fix by downloading and installing the fixed update.
Ford does not have a handle on this system. They are now fixing the fixes and it still has bugs. You and others are right that some people responsible for the touch system do need to get fired. Hopefully the replacements will start by actually listening to their customers.
Good luck!
Old 11-25-2012, 09:30 PM
thanks for the response. I will call the Ford house tomorrow. i did call the sync 800 number and they are useless!!!!! I can read the manual, and have, just like they did. I also did a master reset to no avail.
Will let you guys know the progress.
Old 11-27-2012, 07:31 AM
gcr33 gcr33 is offline
gcr33 is starting off with a positive reputation.
While a little off subject I had an 11 LTD and just got a 13 LTD. The blue tooth noise is goine and it sees after 1 day that the whole thing is much better. We will see.
Old 11-29-2012, 10:17 PM
The red lash fixed most of the problems but sync still sucks, this system is cumbersome. When my iPhone is connected you see it on the screen and the yellow light changes from 1 to 3rd position. What does this mean? I did notice some of the features on my iPod aren't working via Bluetooth when it jumps positions. See below for pic.
Old 11-30-2012, 08:29 PM
ArmamentDawg's Avatar
ArmamentDawg ArmamentDawg is offline
ArmamentDawg is starting off with a positive reputation.
The different lights denote one of three screens that can be viewed. If you press the red area it will switch between the different views.
Old 11-30-2012, 11:18 PM
I pressed it and nothing changed, not on the outside but directly where it says Dax's Iphone. No screen change.
Drove a new Mercedes convertible this weekend... broncoderek 1987 - 1996 F150 & Larger F-Series Trucks 17 06-05-2014 11:44 AM
What's Wrong With Some People? ! ! Ed Oil & Lubrication 18 10-01-2012 11:35 AM
Sync/More than one phone? Redranger03 Escape & Escape Hybrid 2 03-27-2009 01:26 PM
Chrysler rename ag30265 General Automotive Discussion 26 03-08-2007 02:33 AM
SRS trouble bshackelford711 General Automotive Discussion 2 07-29-2005 01:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
