November, 2012 Junk Yard Wishlist
This was a neat idea, thanks again to lgwilson for suggesting this!
Last month's will be unstuck & closed.
Post your wants & needs here, even if they were on last month's list; there's enough chatter on the old one it gets hard to know if somebody is still needing a part or not without reading through the entire thing.
Please keep monetary-transaction talk amongst yourselves - in PMs or e-mail.
It's fine if we want to give/sell things to each other but we can't be running a Flea Market or Auction House here, that's against the spirit of what we do here - people helping each other.
You might also check out the 80-86 Truck Parts - Free to a good home thread.
-chris
-chris
I need a slip yoke for a BW 1356 transfer case ASAP.
Broke mine pulling hurricane downed trees out of the streets.
Still no Internet here, so I am posting from my phone.
After waiting days, the driveline shop got the wrong one!
They had no power yet A/O yesterday.
Will pay for flat rate next day postage.
Thanks!
Thanks!
I need a heater control assembly with a/c and dual tanks switch. Must be a 1980 as they switched the vent to the right of a/c in 81 and mine is to the left of max a/c. Also the rubber vacuum assembly needs to be on the rear. Can't find anyone who sells them.
83-86 clock wiring extension (pigtail)
Hello I need a clock wiring extension from a 83-86 ford truck or bronco. It would be about 2 1/2feet long, on one end have a flat four wire connector for the clock, on the other end it will have a square 8 wire connector with only 4 wires in it that connects to the vehicle's wiring harrness. I belive it would run from behind the clock,and down the right hand side of the radio bezel. I've checked all the local Junkyards with no luck. just let me know what you will take for it...Frank
11/13/12: Think I have found one and it's in the mail. thanks anyway 85 lebaront2. I appericate the offer.
Found a decent set today at Pete's. I no longer need anyone to look, thanks.
There is one on ebay (item #281021437990) it is the whole cluster with tach for a 80-86 diesel. the current bid is $43.00. there is still 3 days left in the auction. today is Nov.15/12. hope this helps ya out.
