1967 F100 4BT cummins daily driver build
Old 07-05-2015, 07:40 AM
f100today's Avatar
f100today
f100today is offline
Originally Posted by bajafishnut
You must be smiling a lot amigo. Your build is way up on the perfect scale, and as close to perfection as a mortal man can expect. Friends are just back from Cuba, and showed us photos of 'Factory Perfect' cars & pickups from the 50's & 60's. Your work would make some of them envious.
Keep smilin'
Baja
Thanks again Baja, I appreciate your comments.
Originally Posted by highntight
X2 with BAja,,, couldn't have said it better, The amount of dedication, time, and skill on this build is beyond me, Should be a sticky without a doubt...
Thank HN! I'm not too sure about a sticky; thats pretty serious stuff. Your build inspires me and makes me jealous all at once! 6BT crew for the win!
Originally Posted by B.Petry
Great build thread! Very nice craftsmanship.
Thank you, it's definitely been a learning experience.
Originally Posted by rustED_
^^^X2...Awesome build, very inspiring! I love white on these trucks, makes them look so classy and the body lines so crisp and clean, of course your talent with body work had alot to do with the clean body lines as well!
I just went back through trying to find some info on the wheels you have, sorry if I missed it, but if you don't mind can you post the size again and where you got them...thanks!
Thanks man! I think Wimbeldon white is the best white out there fer sure. The wheels are 20x8 steelies from Detroit Steel Wheels. 235/55/20 on front and 285/50/20 on back
Detroit Steel Wheel: Steelies, Baby Moons, Bullets, Beauty Rings
  #257
Old 07-05-2015, 09:09 AM
Randle's Avatar
Randle
Randle is offline
She's really looking slick, Good job.
  #258
Old 07-05-2015, 10:27 AM
bajafishnut's Avatar
bajafishnut
bajafishnut is offline
Still over the top amigo, I am loving it, and those wheels.... yeah ..
baja
  #259
Old 07-06-2015, 01:21 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
I'm in as well Tim. Looking at your pics and reading what the other guys have said before me reminds me of two old sayings. "Smooth as a baby's but" and "Cool as the other side of the pillow". The 1st one applies already. The second one will apply once you get some more body panels mounted. IMHO. Way cool Tim, way cool.
  #260
Old 07-06-2015, 08:11 PM
f100today's Avatar
f100today
Thanks guys! It's definitely been a learning experience and tested my capabilities. Wish I could speed it up so I could drive this thing sooner.
Thanks again for the encouragement and comps.
Tim
  #261
Old 07-08-2015, 10:42 AM
bajafishnut
Steady as she goes amigo.. remember, proceed at the "Speed of right", not the speed of light. Taking your time, as you have been, will pay off in the future. I know that you can see where you want to be, way before its time to be there. The closer I get to finishing part of a project, the harder it is to resist the impulse to rush.. Keeping telling yourself.. "The speed of right"... you cannot go wrong with that..
Baja
  #262
Old 07-08-2015, 12:21 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
Is the 6BT the same size as the 4BT but with two
more cylinders added? Like the same bore and all that?
It must be hugeish. As Johnny Depp would say.
  #263
Old 07-08-2015, 06:08 PM
f100today's Avatar
f100today
Yes, many interchangeable parts. Only difference is the block and the crank. Pistons, rods, and other stuff pretty much the same. Pumps are a little different but share the same architecture.
  #264
Old 07-08-2015, 10:25 PM
grinnergetter's Avatar
grinnergetter
grinnergetter is offline
Everything looks great man, nice progress!!!!
  #265
Old 07-09-2015, 09:47 PM
martin72's Avatar
martin72
martin72 is offline
Looking good keep it up you will have it together in no time.
  #266
Old 07-10-2015, 02:00 AM
Jdeshler's Avatar
Jdeshler
Jdeshler is offline
Don't stop in this board that much but I'm glad I did, truck looks killer
  #267
Old 08-15-2015, 10:22 PM
f100today's Avatar
f100today
Been working on lots of stuff. Got the inner fender wells wrapped up finally. Ground the welds, primed them, painted the tops black and the rest of the insides and outsides got Raptor liner. Also primed and painted the Core support. Well, painted the front and did the raptor liner on the engine bay side. Finally got the instrument cluster wrapped up. Since I switched gauges and went with the SpeedHuts, I had to reconfigure my gauge layout. The gauge sizes I originally had were not available with the speed huts so I needed to figure out a way to cover the old and install the new. Basically, I cut the face out of a F600 cluster, wrapped a 3/16 x 1/2 piece of strap around it, tack welded the strap to some sheet metal, then molded the 600 face into it. Finally, Ive been fabbing little stuff like turbo oil returns and what not as well as priming and painting all the little brackets and whatever else I can find.
  #268
Old 08-15-2015, 10:34 PM
f100today's Avatar
f100today
  #269
Old 08-15-2015, 11:17 PM
blue04.5's Avatar
blue04.5
blue04.5 is offline
Gauges look great. Nice touch with the "C"
Mind if I share some pictures with some guys on another forum I am on?
  #270
Old 08-16-2015, 09:20 AM
Tomahawk's Avatar
Tomahawk
Tomahawk is offline
I'm digging the two tone inners, nice touch. The dash is killer.
Quick Reply: 1967 F100 4BT cummins daily driver build
