1967 F100 4BT cummins daily driver build
#196
https://www.google.com/search?q=dimp...ce%3B640%3B480
#197
This kit is pretty sweet as I can punch the holes for the dimple dies with the ram. No need for hole saws. I do wish I had some smaller dies though but this set is enough to keep me busy. It says good to 14 gauge but my frame plates are 10 gauge and it has no issues whatsoever.
I just adapted the power supply with some tractor hydraulic adapters to also run my new JD2 bender.
DDAH105, JMR, 5 Piece Dimple and Punch Kit w/ Air/Hydraulic Pump
The following users liked this post:
#198
And just so everyone knows. These dimpled holes are technically called lightening holes. They are used to make panels stiffer and reduce weight at the same time.
#199
on
That is the exact reason, the military used them in WWII, for landing mats, placing them on soft sand or soil, to make runways and the like, for airplanes & vehicles. Those landing mats, were 10 ga, as I said above, and had the lightening holes, spaced about 3" apart or so. They linked together, with tabs on the sides, and the military had hundreds of thousands of them. I have some, here in Baja, that I have used for years on the beach, when in really soft sand and launching a heavy boat... never get stuck, is my motto.. or always get unstuck it is better
said..
said..
#201
on
Thousands and thousands, but I see them often, and lots of them are fences, and the like uses, at junk yards, coast guard stations, airports, and all over.. Now that I look at my photo, I think that the holes are about 2.5" and almost 6" apart... If you look around, you will see them... I cut one in half, trimmed off the side tabs, and had them rhino coated. They should last me forever, and beyond.. close to invaluable in soft sand or mud...
Baja
Baja
#202
#203
#208
#209
Not much of an update but I started welding in the boxing plates. Looks a little better than the clamps holding it in. Also got the tranny mount finished. I still need to weld the bottom side. Next is the supports for the cab mount cross member then brake line tabs then rear shock mounts then coat the frame.
#210
on
Very, very clean welds amigo. You have a steady hand, and a good eye. After priming, and painting, are you going to undercoat it? On my "Facelift", which is actually only on the bed, I am thinking of "Rhino lining" the inside, if I can find a place to do it in Baja. ?? No clue as to that possibility yet.
How about having the frame rhino lined before you put on the cab... that would sure take care of any rust issues forever...
Baja
Baja
