1967 F100 4BT cummins daily driver build
#406
Wish I could comply compadres; but at this point I just want to get the truck finished and get it on the road. I even contemplated not messing with the tailgate at all and put it on stock. Only reason I didn't is because I am in between painters and waiting on a transmission to be built. The idea seems simple enough though and it definitely would be cool to incorporate into an old bump.
#407
The way lift gate are commonly sprung is a square bar that is anchored on one end and keyed to the pivot pin on the other. When the gate is lowered, the bar is twisted acting like a spring. Last one I rebuilt had a 6' long 5/8" square bar for a four foot gate. A 3/8" bar the length of the gate would probably be quite sufficient for one of these trucks. Anchors would be the only real trick.
#408
Tailgate can be done with a torsion type spring. If you had the right spring it doesn't look like it would be all that hard. Here is a drawing of how they did the spring, and a link to the patent write up on it.
Patent US7500706 - Tailgate spring assist assembly - Google Patents
#410
#411
on
I am thinking that #70 & #80 are springs.. right? Maybe I need to have the parts in my hand, before my brain can wrap around the engineering. Being over 2400 miles from my truck makes the inventing a challenge. I accept the reasoning that NASA did not choose me for Apollo 13, and am OK with it. I am pretty slow with puzzles.
Baja
Baja
#413
Got some goodies on Friday. Just need to get the brake brackets and spring perches welded on then paint the rear end for final mount. Worked on the tailgate a little more Saturday but didn't get much done with all the kids activities this weekend. One thing I have realized in regards to removing paint; either paint stripper sucks these days or the paint they used from the factory on these trucks was bad a$$.
The following users liked this post:
#414
Don't feel bad F100. I just pushed away a girlfriend who's house took all my extra time the past 2 1/2 years. Your kids are a LOT better reason. I've been dyeing to see your rig done also. You took on quite a few things that are different than main stream. I gotta lot of respect for that. And I'm sure there are a lot of others here. But you know something? I respect you more for putting your kids as TOP priority. This may be the wrong place for me to say these words, but for some reason I felt they needed to be said. So I did.
#416
#417
Been a while but I finally got the tailgate fabbed up. Well, the outside at least. I'm not the first person to do this; got the idea from Kirk Johnsons silver 68. But I might be the second, I've never seen it on any other truck. Regardless, all the rough body work is finished, just need to hammer on a few small dents before I weld the inside panel back in and make a handle. I will pretty much make something like Randle did.
Bonding the ford script on. Had to find some heavy stuff.....
And the finished product
#418
Keep up the awesome work.
Sean
#419
Might have picked up my next project. Buddy of mine is giving it to me for super cheap. 66 Fairlane. I have always loved the 67 Boss Fairlane Bobby Allow built a few years ago. I pretty much have the rear end, wheels and tires, a/c, seats, and some other stuff. It will also be wimbledon white but with a red interior. Instead of a big block I will go with a 5.0 Coyote with a 6 speed. I will probably go more traditional and simple with my 65 comet.
#420
Thanks man. Congrats on the race track thing. If you are going to SEMA I will see you there; I plan on going this year. Also, expect a PM from me in the future, I need some info from you on the coyote thing as well as some of the CV brake stuff. Believe it or not, I might use some CV stuff in my fairlane build. Minus the crossmember and rack that is
