Diesel Powered Coolant Heater - Ford Truck Enthusiasts Forums
Old 11-25-2012, 12:02 AM
ol-blu's Avatar
ol-blu ol-blu is offline
ol-blu is starting off with a positive reputation.
Sourcing out either a Webasto OR Espar heater for my 2004 F250 6.0..... Webasto makes a "generic" kit for their product, but nothing vehicle specific... Has anyone on this site installed or knows how to tie into the fuel system properly??? I know that I have to tie into the Fuel system BEFORE the In-Frame pump, just don't know how to do so in a SAFE manner..... The initial lines coming from the tank to the pump are a plastic/ rubber material, can I just use a "T" type fitting (not sure what material will be Diesel safe) and tie into the feed line to the pump??
I'm afraid if I tie into the lines after the pump, either the excess fuel pressure will blow the connection apart, or the fuel pressure will damage the fuel pump/system in the Heater itself... Any ideas or tips guys???
Thanks and cheers!!!!!!!!
Old 11-25-2012, 07:55 AM
dannyboy950 dannyboy950 is offline
dannyboy950 has a very good reputation on FTE.dannyboy950 has a very good reputation on FTE.dannyboy950 has a very good reputation on FTE.dannyboy950 has a very good reputation on FTE.
Not familiar with the unit. I went to their website but couldn't find a manual.
I would think they would provide a instalation kit like the Airdog Fuel system does with the necerrary hoses and fittings.
Sorry I wasn't more help.
Old 11-25-2012, 09:24 AM
Corner Gas's Avatar
Corner Gas Corner Gas is offline
Corner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant future
I saw someone had installed a wabaso on their truck, maybe try a google search.
Old 11-25-2012, 09:38 AM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
Might be best to mod the fuel tank and install a dedicated pick-up for the unit. It could then be installed short of the bottom of the tank, preventing it from running the tank dry.
Old 11-25-2012, 09:40 PM
berick's Avatar
berick berick is offline
berick is gaining momentum as a positive member of FTE.
I've got an Espar unit but had the company who sold it to me do the installation. Great unit though!
Custom E-Fuel 7.3 Conversion 0500757Arf 1987 - 1996 F150 & Larger F-Series Trucks 0 10-19-2016 08:55 PM
86 F250 Super Cab fuel line replacement f100beatertruck Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 06-22-2016 10:07 PM
Nest auxiliary function options for command start Ebaum744 1999 to 2016 Super Duty 0 11-13-2015 12:50 PM
Bypass fitting on F350 Radiator- Can I use for coolant filter/heater bypass? My plan is: Fixnstuff Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 10-19-2015 07:11 AM
diesel fuel fired block heater johnnynegaunee Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 01-09-2006 06:46 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
