55 F-100 and Gearhead column
I purchased a Gearhead steering column with no ignition switch or column shift.
I am having major issues trying to get the turn signals, brake lights, etc to work properly. There does not seem to be an internal ground wire from the column on this unit and a friend thinks that the issues I am having is due to a lack of ground on the column. Trying to wire according to the GM wiring diagram for the column.
Has anyone else had such issues and where did you ground the column, ie drill a small hole for a ground screw in the column, etc?
Thanks,
Thanks,
ike55
02-28-2012 07:44 AM
nojeffgordon
11-18-2004 05:54 AM
