Brake lights always on
Need help. Have a '68 F100 flareside. My brake lights are always in the "brake" position, meaning it looks like I'm standing on the brakes. This only happens when I also have the lights on, even in the parking light setting. So I spent the last two days re-wiring from the fire wall to the tail lights. Found some mushy 4-wire connections in the bay, fixed them too. Put a new fuse in, turned on my lights, turned my key to ON. Had turn signals at this point. Hooked up my brake switch with my finger on the plunger keeping it off. Let fly on the switch and the 20A fuse blew. Began chasing wires thru the dash, but it's getting dark and I can't think straight after chasing this ghost in the machine. I read the other posts and someone suggested the turn signal switch. Is this correct? With the blown fuse I have ON brake lights, none if the key is off. Hook up the brake switch, and either blow a fuse or start a fire if I try to jump or tin foil it. I need help, this is driving me crazy.
Thanks,
Joe
Thanks,
Joe
I would investigate the turn signal switch. Maybe unplug it and test the wires. With no power, see if you get any leads to go to ground with an ohm meter.
There are only 4 wires going to the rear of the truck for the lights to function, so if you fixed that already, then it is likely inside the truck.
This switch was used on 1969/72 F100/350's only. So, you either have a 1969 F100, or someone changed the brake pedal.
1967/68 F100/350 uses a totally different switch. Pushrod has a hole in it, switch (it's rectangular) has two holes, pushrod fits in between them.
Bolt passes thru switch-pushrod-switch then thru hole in brake pedal, nut retains it.
Post the last 6 digits of the VIN, this will verify the year.
Josethef100
21
07-14-2019 06:19 PM
hrp77573
09-18-2010 06:09 AM
