Brake lights always on - Ford Truck Enthusiasts Forums
Old 11-24-2012, 06:14 PM
mnkeeking mnkeeking is offline
mnkeeking is gaining momentum as a positive member of FTE.
Need help. Have a '68 F100 flareside. My brake lights are always in the "brake" position, meaning it looks like I'm standing on the brakes. This only happens when I also have the lights on, even in the parking light setting. So I spent the last two days re-wiring from the fire wall to the tail lights. Found some mushy 4-wire connections in the bay, fixed them too. Put a new fuse in, turned on my lights, turned my key to ON. Had turn signals at this point. Hooked up my brake switch with my finger on the plunger keeping it off. Let fly on the switch and the 20A fuse blew. Began chasing wires thru the dash, but it's getting dark and I can't think straight after chasing this ghost in the machine. I read the other posts and someone suggested the turn signal switch. Is this correct? With the blown fuse I have ON brake lights, none if the key is off. Hook up the brake switch, and either blow a fuse or start a fire if I try to jump or tin foil it. I need help, this is driving me crazy.
Thanks,
Joe
Old 11-24-2012, 08:41 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
I would investigate the turn signal switch. Maybe unplug it and test the wires. With no power, see if you get any leads to go to ground with an ohm meter.
There are only 4 wires going to the rear of the truck for the lights to function, so if you fixed that already, then it is likely inside the truck.
Old 11-25-2012, 04:47 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Joe to add to FT, have you done any work on the electrical anywhere on the truck?
You might want to check at the master cylinder, with the ign switch on, one wire should be hot the other not, if both are hot the brake light switch is bad, allowing current to pass at all times.
John
Old 11-25-2012, 05:33 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by mnkeeking View Post
I have a 1968 F100.
If the switch has a plunger on one end, it's round and has threads below the plunger.
This switch was used on 1969/72 F100/350's only. So, you either have a 1969 F100, or someone changed the brake pedal.
1967/68 F100/350 uses a totally different switch. Pushrod has a hole in it, switch (it's rectangular) has two holes, pushrod fits in between them.
Bolt passes thru switch-pushrod-switch then thru hole in brake pedal, nut retains it.
Post the last 6 digits of the VIN, this will verify the year.
brake/turn signal power. mweeks 1961 - 1966 F-100 & Larger F-Series Trucks 0 05-20-2015 08:46 AM
Help! Fuse 13... 77_F150_4x4 1987 - 1996 F150 & Larger F-Series Trucks 2 05-13-2014 01:36 PM
68 F100 LWB Brake Lights/Turn Signal Problem r0cker 1967 - 1972 F-100 & Larger F-Series Trucks 7 01-09-2014 03:34 PM
Need help with rear lights! 02SuperPoop 1999 to 2016 Super Duty 12 12-29-2013 09:54 PM
wired up taillights, no turn signals, no brakes... where does brake signal come from? hasteranger 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-20-2012 01:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
