1992 F-150 Running Cool
Old 11-24-2012, 06:07 PM
capriceragtop's Avatar
capriceragtop
capriceragtop is offline
Hey all,
My truck is running cool. The needle sits on the first line of the normal range, so the gauge does move.
Here are some things I've done to the coolant system:
New upper and lower hoses.
New radiator and cap.
New thermostat.
Flushed and filled.
The heater blows warm, but not exceptionally hot. The upper hose doesn't get firm, even after running for a while. Neither does the lower hose. The lower hose remains cool. The upper hose gets warm, but not too hot. The radiator gets warm, but not too hot. The radiator cap remains cool. When I remove the radiator cap, even after running a while, there is little to no pressure release. My heater lines are hot.
So, am I looking at needing a new thermostat or a new water pump?
Old 11-24-2012, 06:23 PM
HotrodSmurf's Avatar
HotrodSmurf
HotrodSmurf is offline
tstat's what ya need. Although mine always ran cool even after changing tstats, not to the extent you describe but the gauge never read past the "n" on normal, even with cardboard over the radiator for winter.
Old 11-24-2012, 06:41 PM
70torino429's Avatar
70torino429
70torino429 is offline
Did you get a 195 T-stat or a 180?
Old 11-24-2012, 06:43 PM
capriceragtop
That was my next question actually. I can't remember which temp I got. Pretty sure I went back with what Autozone showed as "stock."
Old 11-24-2012, 06:54 PM
70torino429
I think stock is 195, so that *should* be what they gave you. My truck with a 180 T-stat never would run warm enough to run the heat very strong in the winter. I still think the T-stat is probably your problem though, that's really the only component that can make it run too cold. I've had the same problem in a Crown vic of mine where the thermostat broke into two pieces and was just functioning fully open all the time.
Old 11-24-2012, 07:01 PM
capriceragtop
I'll run with a 195, then. Also, I'm beginning to suspect my fan clutch. I think the fan turns at all times. I'm curious to see how if she still smokes once she gets properly warmed up. Bet she will, but here's hoping!
Old 11-25-2012, 05:05 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I would suspect the thermostat too. Get a 195 Motorcraft one instead of an A'zone one.
Can you hear the fan spinning all the time? Check to see if your fan can be rotated by hand with minimal effort. If so, the fan clutch isn't stuck.
Are you sure its running too cool? Whats the temp gauge read?
Old 11-25-2012, 09:10 AM
timbersteel's Avatar
timbersteel
timbersteel is offline
I agree with texasguy. Replace any OEM brand t-stat with genuine manufacturer part. Just replaced a junk t-stat from parts house with correct t-stat from Mopar @ $30, but it's not worth my time to change again when another, "Certified" mechanic replaced it with a $10 one. Also as texasguy stated, check the operation of the fan clutch to eliminate it as the problem as well.
Old 11-25-2012, 09:28 AM
Weberman3's Avatar
Weberman3
Weberman3 is offline
Not to hijack but since we are on the topic.. I flushed the system last Saturday. Is it possible there is still air in the system? When I check it it seems low, and all the coolant in the reservoir is gone too. It also gets to the middle of the N in normal.
Old 11-25-2012, 09:33 AM
timbersteel
Very good possibility. I always keep extra coolant around after a flush and fill, or anything involved with draining the coolant, as this allows air back into a once sealed system.
Old 11-25-2012, 09:47 AM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Bad Bad Leroy Brown is offline
^ +1
I had to top off my overflow tank every day for like a week of driving and it finally stoped getting low after all the air got worked out while driving.
Old 11-25-2012, 10:11 AM
Weberman3's Avatar
Weberman3
I busted a hose 3 months back driving and drained my coolant system that way..just put water in it last saturday. It threw fits at me for at least two weeks after I replaced that hose.. It was never satisfied about its level.. It either sucked it all up and I put some more in the reservoir and then when I learned it and went to do something and I come back with water all over the ground.. I opened the hood and found the cap off with water all over the tank. Its just been sucking it in now, hadn't throw it back out.
Old 11-25-2012, 06:19 PM
Weberman3's Avatar
Weberman3
Good news. It finally found its happy spot on coolant. There was still some left in the reservoir. Bad news.. Hit a ditch and the radiator is leaking somewhere.
Old 11-26-2012, 12:07 PM
capriceragtop
Got a new thermostat from Ford. They show stock as 192. Going to test the fan clutch today and put in the thermostat if there's time.
Old 11-26-2012, 12:53 PM
capriceragtop
All,
I just checked and my fan is spinning the moment the motor starts turning. I can turn it by hand with the motor off, but it won't freewheel, ie it will stop spinning if I'm not actively turning it.
Is my fan clutch bad? And if so, am I smarter just hauling off and replacing the water pump while I'm at it?
Quick Reply: 1992 F-150 Running Cool
