Breather bolt in the nine inch rear end
Old 11-24-2012, 11:11 AM
Bigbruce's Avatar
Bigbruce
Bigbruce is offline
Were can i buy a new one it holds part of the rear brake lines to the rear end .
Old 11-24-2012, 11:33 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
There is no bolt.
The rear brake hose has a brass block made as part of it w/a hole in it. The rear axle vent passes thru the hole, threads into the housing, retains the brass block in place.
E7TZ-4022-A (replaced E3TZ-4022-D, D1OZ-4022-A, C2OZ-4022-A & B7A-4022-A) .. Rear Axle Vent ~ 7/16" -20 x 2 1/32" long.
1957/86 9" rear axles / 1962/80 8" rear axles / 1986/97 Aerostar and etc etc etc.
Old 11-24-2012, 01:43 PM
gumshoe's Avatar
gumshoe
gumshoe is offline
best bet would be a yard like pic & pull, maybe napa
Old 11-24-2012, 02:30 PM
Bigbruce's Avatar
Bigbruce
Bigbruce is offline
thanks #dummy that is part I am looking for do you think I should try the local ford dealer with that part #
Old 11-24-2012, 02:40 PM
Bigbruce's Avatar
Bigbruce
Bigbruce is offline
I found them on ebay
Ford rear axle vent #E7TZ4022A | eBay
thanks for the info
Old 11-24-2012, 05:18 PM
hasteranger's Avatar
hasteranger
hasteranger is offline
jbg sells a fancy one too, if the factory one isn't good enough. lol.
Old 11-24-2012, 09:41 PM
Vinford's Avatar
Vinford
Vinford is offline
Got mine at my local NAPA.
I broke the bolt off that held it to the rrear end then tryed to drill itout.
Things are in a mess ........................
Old 04-16-2017, 06:01 PM
hotrod1966's Avatar
hotrod1966
hotrod1966 is offline
I could not find the correct bolt locally so I replaced my vent 1966 bolt with a Dorman 924-263 (F5UZ-4022-A). It cost $8.49. It uses a 11/32 ID hose.
Vinford
01-23-2009 10:04 PM
john fin
05-13-2007 12:22 PM
rchassie
03-07-2003 07:24 PM
GeneStoner
03-01-2003 10:40 PM
GeneStoner
02-28-2003 08:56 PM
Quick Reply: Breather bolt in the nine inch rear end
