Breather bolt in the nine inch rear end - Ford Truck Enthusiasts Forums
Old 11-24-2012, 11:11 AM
Bigbruce Bigbruce is offline
Bigbruce is starting off with a positive reputation.
Were can i buy a new one it holds part of the rear brake lines to the rear end .
Old 11-24-2012, 11:33 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
There is no bolt.
The rear brake hose has a brass block made as part of it w/a hole in it. The rear axle vent passes thru the hole, threads into the housing, retains the brass block in place.
E7TZ-4022-A (replaced E3TZ-4022-D, D1OZ-4022-A, C2OZ-4022-A & B7A-4022-A) .. Rear Axle Vent ~ 7/16" -20 x 2 1/32" long.
1957/86 9" rear axles / 1962/80 8" rear axles / 1986/97 Aerostar and etc etc etc.
Old 11-24-2012, 01:43 PM
gumshoe gumshoe is offline
gumshoe is starting off with a positive reputation.
best bet would be a yard like pic & pull, maybe napa
Old 11-24-2012, 02:30 PM
thanks #dummy that is part I am looking for do you think I should try the local ford dealer with that part #
Old 11-24-2012, 02:40 PM
I found them on ebay
Ford rear axle vent #E7TZ4022A | eBay
thanks for the info
Old 11-24-2012, 05:18 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
jbg sells a fancy one too, if the factory one isn't good enough. lol.
Old 11-24-2012, 09:41 PM
Vinford's Avatar
Vinford Vinford is offline
Vinford has a good reputation on FTE.Vinford has a good reputation on FTE.
Got mine at my local NAPA.
I broke the bolt off that held it to the rrear end then tryed to drill itout.
Things are in a mess ........................
Benefits of a "Locker" rear end? GeneStoner Clutch, Transmission, Differential, Axle & Transfer Case 10 01-20-2005 11:21 PM
2 speed rear ends countrymike Clutch, Transmission, Differential, Axle & Transfer Case 3 12-12-2004 02:51 PM
Gen1 Rear end ratio? 95 BRONCO XLT Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 1 04-18-2004 11:15 PM
1968 F250 Rear End jambroson 1967 - 1972 F-100 & Larger F-Series Trucks 14 04-02-2004 12:46 PM
rear end ID numbers? StockMan 1967 - 1972 F-100 & Larger F-Series Trucks 4 06-04-2002 08:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
