trouble filling up
trouble filling up
I am having trouble filling my 2005 F-250 Super Duty. It has a 5.4 gas engine. I have checked the fill vent and cannot fing anything wrong. I read somehwere on here that there is a cannister that is attatched to the vent line above the rear axle. This cannister can be cleaned with compressed air? Has anyone heard of this?
trouble filling
Is not very much info on what the problem is. You need to give more
details. Is it spitting gas all over the place or not filling all the way or
the nozzle won't go in. The canister question gives me ideas but doing that is
assuming things and you that does ****u*me
So please post more info on what is going on
Sean
Sean
You may want to check out this thread that I started when I could not figure out what that component was - https://www.ford-trucks.com/forums/1...the-spare.html
In that thread there are pictures I took of the vapor canister, including where it is located.
There is also a link to another thread and a TSB about the problems with the canisters on the 2005s.
I will not ***-U-ME this is your problem, but you might be interested anyhow.
Thread from the past about slow fill/ clicking off while filling.
https://www.ford-trucks.com/forums/8...fuel-fill.html
Bulletin about the slow fill issue.
https://www.fleet.ford.com/truckbbas...tml/Q132R1.pdf
More Info.
My truck is a 2005 F-250 SD with a 5.4 V8 with auto. trans. When I try to put gas in the tank, the nozzle keeps clicking off like the tank is full. There is no gas in the tank when this happens, because I have run it out of gas numerous times. I should also mention that the gage does not work. However the truck run like a scalded ape, I just can't get it to take gas at the filling station. It spits gas back on occasions, but not all the time. Any information would be appreciated.
Sounds like a plugged vent line. You will have to look under the truck
where the fill line goes into the tank. You should see two lines going to the
filler neck and the smaller one should be the vent. If it has a kink in it that
can be a problem. The lager one is the fill line and it could also have a kink.
As to the level problem it can be anything from a bad sender or as simple
as an open furs or a broken wire. Do you have any access to a scan tool?
You can check to see if you have codes for the fuel level system and als
look at live data for the level sender. After that it down to checking things
with a DMM (Digital Multi Meter). There should be some info on what the
meter readings should be if you check the level sender with the meter.
Look in the Tech Folder.
Sean
Sean
TSB
06-19-15
SLOW FUEL FILL
Publication Date: September 18, 2006
FORD:
2005-2007 F-250, F-350
ISSUE:
Some 2005-2007 F-Super Duty 250/350 vehicles may experience premature automatic shut off of the fuel fill nozzle, or repeated fuel shut off at the fuel station delivery nozzle. Vehicles operated in muddy or dusty environments can encounter a dirt-clogged carbon canister system. More specifically, the carbon canister's vent, fresh-air box, and filters, clogged with dirt from operating in such environments.
ACTION:
Use the following Service Procedure to resolve the concern if the carbon canister system is dirt clogged.
NOTE: THIS TSB ONLY APPLIES TO F-250/350 PICKUPS, AND F-250/350 PICKUP BOX DELETE / CHASSIS CAB VEHICLES.
SERVICE PROCEDURE
Inspect the vehicle carbon canister system and if it is found to be dirt clogged then continue with this TSB.
NOTE: IF THE VEHICLES CARBON CANISTER SYSTEM IS NOT DIRT CLOGGED, THEN PROCEED WITH NORMAL DIAGNOSTICS AND DO NOT CONTINUE WITH THIS TSB.
Vehicles with Pick Up Boxes:
If the vehicle was built on or after 9/14/2006, proceed to Step 2. If the vehicle was built prior to 9/14/2006, replace the carbon canister assembly. This carbon canister has a revised internal filter media.
Relocate the fresh-air intake port to a more protected location using the Fresh Air Hose Kit, for pick up applications only.
Vehicles with Pick Up Box Removed or Chassis Cab:
Relocate the fresh-air intake port to a more protected location using QVM bulletin Q-132 at the body builder's website - https://www.fleet.ford.com/truckbbas/index.htm for fresh air intake routing recommendations.
PART NUMBER PART NAME
7C3Z-9049-A Fresh Air Kit
6C3Z-9D653-AB Carbon Canister - Pick up
6C3Z-9D653-DB Carbon Canister - Chassis Cab
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
061915A 2005-2007 F-Super Duty 250/350: Inspect Canister Vent Fresh-Air Box, Replace The Carbon Canister Assembly, Install Fresh-Air Kit (Do Not Use With 9653A) 1.2 Hrs.
061915B 2005-2007 F-Super Duty 250-350 Built On/Or After 09-14-2006: Inspect Canister Vent Fresh Air box, Install Fresh Air KitDo Not Use With 9653A) 0.4 Hr.
DEALER CODING
06-19-15
SLOW FUEL FILL
FORD:
ISSUE:
ACTION:
SERVICE PROCEDURE
WARRANTY STATUS:
DEALER CODING
1975Ford
06-14-2007 10:28 AM
