truck is eating fuel pumps...
I thought it was just the Airtex pumps failing because they are junk, but the truck ran for literally five minutes before the ford o.e. pump I got from a junkyard truck with a very clean tank quit working. I tested it before installing. The the pumps are failing electrically, but I can't figure out why. I've been all through the harness and found no loose/broken/grounded/etc wires. I've also tested the alternator and its not over voltage or anything. I don't get it.
With your meter set to low ohm scale you should read about 10 Ohms across the motor terminals.
It's possible to have a bad connection either on the power side or ground side that measures 12V but will not sustain voltage under load.
Problem could be anywhere in the circuit. Dash switch, tank selector, sender connector or anywhere in between.
Here is a diagram of your system (from '86 shop manual):
http://imageshack.us/a/img38/2729/460dualtanksel.jpg
Luthoro, these pumps are only supposed to have 12v during cranking, there is a resistor that feeds through the relay once the oil pressure comes up. There are more pages to that whole system, go to my website and under downloads is 86_7.5L_fuel_pumps, that is the whole thing. I have a good front pump from mine and possibly rear.
To test the pump you need to disconnect the connector and measure at the pump terminals on the sender.
Here is the shop manual version of the relay circuit to go along with the other diagram I posted.
http://img441.imageshack.us/img441/1029/460pump.jpg
What did you jumper exactly the oil pressure switch or the oil pressure sender?
