turbo power loss - Ford Truck Enthusiasts Forums
turbo power loss
Old 11-23-2012, 04:39 PM
johnthevon johnthevon is offline
johnthevon is starting off with a positive reputation.
turbo power loss
Hi folks I have a 2002 350 7.3 my turbo boost cuts out when it gets to 10 psi seems to work ok until "she" gets warmed up then when I floor it my boost Gauge shoots to 11si the {she) just cuts out psi falls and I have no power. Thought it was water have changed the filter and drained the bowl many times but the problem keeps coming back, johnthevon@yahoo.com
Old 11-23-2012, 06:23 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
sounds like turbo surge to me. Also, Remove the intake assy and grab ahold of the compressor wheel. See it it wobbles around.
Old 11-23-2012, 06:41 PM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
It doesn't sound like surge at all to me...
Are you getting an SES light? Any codes?
Check to make sure you don't have any tears in the intercooler boots, line off going to the MAP sensor. If you believe you are having a fuel restriction issue, at least get a temporary fuel pressure gauge on their to check it at WOT.
Old 11-23-2012, 11:16 PM
MTDewX's Avatar
MTDewX MTDewX is offline
MTDewX is gaining momentum as a positive member of FTE.MTDewX is gaining momentum as a positive member of FTE.
does it just die out fullly or will the power come back if your holding the peddle to GO mode?
surge I had tends to be Power, then lag. power. then lag again. making you feel like something was wrong.
I ended up getting a rebuilt stock turbo with a WW and changed nothing else.
no more surge. I didnt have crazy mods. just a had held tuner type of thing.
Old 11-27-2012, 12:52 AM
Red face 2002 7.3 power stroke
Guys and gals thank you for replying to my post but to be honest with you the last time I really new anything about cars was when I owned a 68 camaro. So I really don't know allot of what the hell your telling me. I have turbo boost but when I floor it the psi goes to 10 psi ( i have A pillar gauges) when I do floor it psi shoots to 10 psi then turbo just cuts out and I have no power even if I keep it floored. when I release the pedal all is well. I find if I don't floor it I have turbo and boost past 10 psi thanks for you patience
Old 12-01-2012, 03:29 PM
ok guys what is a turbo surge
Old 12-01-2012, 10:24 PM
1fixitman's Avatar
1fixitman 1fixitman is offline
1fixitman has a very good reputation on FTE.1fixitman has a very good reputation on FTE.1fixitman has a very good reputation on FTE.
A lot of power and then no power and then a lot of power and then no power and a lot of power and then no power and a lot of power and then no power. This is what surge is.
Old 12-01-2012, 10:33 PM
BigAlsPSD's Avatar
Quote:
These video's are good examples of surge, not seriously noticeable in power though. It is a rapid stalling of the compressor wheel repeatedly.
<iframe width="560" height="315" src="http://www.youtube.com/embed/GE9vz9s1xYw" frameborder="0" allowfullscreen></iframe>
<iframe width="420" height="315" src="http://www.youtube.com/embed/evGFfuhUaRM" frameborder="0" allowfullscreen></iframe>
Old 12-01-2012, 10:49 PM
BigAlsPSD's Avatar
Is there a noticeable lack of power or sound change associated with what the gauge says?
What I'm getting at is this a gauge/hose issue possibly or are you actually losing boost?
If you can feel it, as I said earlier, I would want to check for boost leaks, such as the boots that clamp the charge pipes together, and up pipes for leaks as well, after looking for boost leaks I would want to try to monitor live data from the PCM to see what the MAP sensor is reading as well as the ICP(Injector Control Pressure) sensor and IPR, beyond that I would want to check fuel pressure.
Old 12-03-2012, 04:48 PM
turbo loss
Oh man you guys are great I can't you enough for you patients with "one of jerrys kids" ME.I watched the 2nd video twice and that is kinda sorts what my truck is doing if I floor it my psi go to 1o psi then just drops to o but is I go with Half throttle I have a steady boost to what ever is that still surge?
Old 12-03-2012, 05:01 PM
thanks for your help man. is there a certain way to check for leaks around the hoses and stuff
boost problems 6.0 Zach85 6.0L Power Stroke Diesel 14 06-30-2014 09:02 PM
Boost, wastegate, turbo related question. dothedew192 1999 - 2003 7.3L Power Stroke Diesel 38 10-26-2013 04:43 PM
low boost after about a mile or so also speedometer quit busabuggy 6.0L Power Stroke Diesel 23 11-02-2012 01:26 PM
Turbo rattle/loosing boost No_BS 1994.5 - 1997 7.3L Power Stroke Diesel 11 06-14-2012 06:23 AM
turbo psi?? davidson915 1999 - 2003 7.3L Power Stroke Diesel 17 01-24-2008 06:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
