Locking Gas Cap? - Ford Truck Enthusiasts Forums
5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
Locking Gas Cap?
Old 11-23-2012, 01:44 PM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
Locking Gas Cap?
Anyone know of a locking gas cap for my 2011 5.0L XLT?
It has that wierd new kind that is capless but I want one that locks so people can not take my gas.
Old 11-23-2012, 04:24 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
well, I can understand the desire but typically the secondary response from the thief is to just place the container under your truck & with a pick, punch a hole in the bottom of the plastic tank...it drains faster than siphoning.....
a better soltuion/recommendation is to run with just 1/2 tank...it's a little harder to siphen out of........
Old 03-17-2013, 10:45 PM
gDMJoe's Avatar
gDMJoe gDMJoe is offline
gDMJoe has a very good reputation on FTE.gDMJoe has a very good reputation on FTE.gDMJoe has a very good reputation on FTE.
*FoMoCo part # 8U5Z-9C268-B
-click- the pic'
Goth 150
< This space intentionally -blank- >
Old 03-18-2013, 06:08 PM
gregsf150xl gregsf150xl is offline
gregsf150xl is starting off with a positive reputation.
Exclamation
I just bought one of these for $22.00 on Ebay from a Ford Dealer.
More of a locking "plug", since the new F150's have the capless design.
Still weird having an open space there. This little plug seals it off.
Old 08-02-2013, 03:55 PM
flowgoode's Avatar
flowgoode flowgoode is offline
flowgoode is starting off with a positive reputation.
This is awesome...didn't know they even made something like that! It's still weird looking at where a gas cap "should be".
Old 08-02-2013, 04:36 PM
03 SVT VERT 03 SVT VERT is offline
03 SVT VERT has a good reputation on FTE.03 SVT VERT has a good reputation on FTE.03 SVT VERT has a good reputation on FTE.
It's worth noting that you can't siphon the latest gen of trucks, at least not in the traditional way. The capless design won't unlock unless you use a fuel nozzle or specially shaped funnel, then you've got a ball-and-cage valve behind it, to prevent evaporative emissions. (Which, coincidentally, also prevents a hose from going down the filler tube.)
With most vehicles nowadays it's easier to siphon from underneath. People that do it legally disconnect the filler tube, either on the body end or the tank end, and then siphon accordingly. People that do it illegally will just punch the tank. We had a lot of practice with the former during Hurricane Sandy.
Old 08-21-2013, 04:31 PM
04 FX4 Lineman 04 FX4 Lineman is offline
04 FX4 Lineman is starting off with a positive reputation.
Does anybody know where I could get one of these caps that is not locking, just want one to keep dirt out??
Old 08-29-2013, 10:50 AM
Truck Guy99's Avatar
Truck Guy99 Truck Guy99 is offline
Truck Guy99 has a good reputation on FTE.Truck Guy99 has a good reputation on FTE.Truck Guy99 has a good reputation on FTE.
You could just get a locking one like above and don't lock it.
Old 08-29-2013, 05:27 PM
Quote:
Thanx I may try that was just thinking they had to be locked to get the key out, Have had that kind in the past??
Old 08-29-2013, 05:34 PM
I had one on my 87 f150. You could leave it unlocked. Then again that wasn't the capless filler neck
Old 08-29-2013, 05:47 PM
I am thinking I may try it anyway am just afraid dirt and junk will get in the filler, not real impressed with this type of spout
Old 01-08-2014, 11:30 PM
Buck268's Avatar
Buck268 Buck268 is offline
Buck268 is starting off with a positive reputation.
Obviously I have this on my truck, had in on my '12 Mustang before as well. As mentioned above, you cannot siphon through the filler opening on these vehicles and I never had an issue with contamination from the open access. Might be an issue as the vehicle ages but at least initially that little rubber gasket around the door works better than you'd think.
Locking Gas Cap Rob89 1999 to 2016 Super Duty 10 01-15-2017 07:44 AM
no key for locking gas cap moconnor603 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 11-26-2016 09:25 AM
locking gas cap 69issofine 1967 - 1972 F-100 & Larger F-Series Trucks 8 12-10-2014 12:59 PM
locking gas cap michael cook 2009 - 2014 F150 16 12-01-2011 03:13 AM
Locking gas cap jd_sylvia 1961 - 1966 F-100 & Larger F-Series Trucks 10 06-09-2007 04:04 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
