Bbk throttle body 97 460 adjust?
Installed and works fine - seems to pull harder throughout rpm range but haven't really got to check it out yet. I have read a lot of post on this. My tps is non adjustable but still would like to check the volts. Install paper says green wire. DO I JUST POKE THE METER INTO THE WIRE?
Back probe it at the connector with a t pin if you have a wife or girlfriend that sews I'm sure they have some if not go to the sewing section and buy a pack way cheaper then what the parts stores sell
http://m.joann.com//dritz-t-pins/prd3129/
