08 fumes in the cab
[quote=Gearitis;12516606]Like senix said, check the downpipe, an important area that could leak enough to cause the smell. Senix has been around these boards a long time and has a good sense of issues on these trucks.[/quote
Nope...just burn alot of fuel and get lucky..there is something you pointed out though and that is the tailpipes. Maybe unrelated or related. If they are dirty then maybe it is tuned or the DPF maybe bad as well.
Exactly, my pipes were black, so I did a visual on the DPF and was showing no cracks, but the Diesel Tech did some test and showed leaking backpressure? and also the tell tail sign of black exhaust.
Nope, not taking it that way, we are all learning here. My truck never threw a code. I just had fumes, especially during regen. When I came to a stop and it was in regen, there were times I thought I was going to choke. Other times was not as bad when not in regen but could still smell it. I understand as I am the same as you, if its cracked and it does not crack outside then how does it fume. To tell you the truth, I don't know. But I do know after the new DPF went in, it has been all well.
2 days at the dealer nothing found but my wallet is 2 hundred lighter.
Remember my orginal post when i bought the truck
When i bought the truck the CAC was bad the dealer changed it and put the latest tune on and replaced the fuel filters. They say that is why the tails are black. I have been using the motorcraft fuel additive with every fill up like the tech suggested. Could this be the problem with the black tails just getting it cleaned out.
