differential problem for 1991 F-150
Old 11-21-2012, 08:28 PM
pugbro's Avatar
pugbro
pugbro is offline
Red face differential problem for 1991 F-150
I have a 1991 F-150 XLT Lariet that Has 204,000 miles on it. Yeah the eng and tran have been changed. Recently I had to replace the differential..The first switch was as bad as the one I took out....whined like a banshee! The second one which is in the truck now has a lot of loose play and will all most give you whip lash if you take off fast and sounds like someone with a hammer banging on the rear end. I can't afford to keep buying used units out of old 91's until maybe I will find a good one.
Does anyone know of a newer model unit that will fit without a bunch of modifications. I can replace the chunk but that is a little out of my budget.
Thanks
Old 11-21-2012, 10:35 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
There is no "chunk" in the Ford 8.8" rear axle you have in your 1991 F-150. Any Ford truck 8.8" axle in the 87ish (or older) through 1996 will work as a replacement.
Old 11-22-2012, 09:04 AM
pugbro's Avatar
pugbro
pugbro is offline
I was hoping that someone might know of a year model newer than the 90's that might fit. Most of the salvage yard units are much like the one I have (lots and lots of miles).
Thanks for the input.
Old 11-22-2012, 09:48 AM
preppypyro's Avatar
preppypyro
preppypyro is offline
Where are you located? I have a good one sitting in my shop that Im probably going to end up throwing away. 3.55 gears if I remember correct.
Old 11-22-2012, 10:17 AM
pugbro's Avatar
pugbro
pugbro is offline
Thanks a million for the offer..However I live in a small town about 50 miles NW of Atlanta, GA
Old 11-22-2012, 10:47 AM
preppypyro's Avatar
preppypyro
Wee bit far from western Canada haha.
Old 11-22-2012, 11:34 AM
pugbro's Avatar
pugbro
pugbro is offline
Amen brother but efforts like yours makes me realize there are still some good folks in this world...Thanks again!
Old 11-22-2012, 12:14 PM
rla2005's Avatar
rla2005
I agree with that statement 100%. I have never had any luck finding a decent drive axle from a salvage yard that didn't require some repairs to bring it up to par. On the other hand having a "spare" allows you to rebuild it then install at your leisure.
I have rebuilt several front and rear axles in my home garage with no air tools over years. It's not rocket science, but you do need a few tools and some patience.
Old 11-22-2012, 12:51 PM
Puddy's Avatar
Puddy
Puddy is offline
Yup... Sounds familiar.
elliot
04-05-2017 09:28 PM
mseeley79
05-19-2011 03:42 PM
Babin
02-26-2011 01:10 PM
Milwaukee1979F150
09-29-2008 12:55 PM
sumoboy
01-30-2004 09:26 AM
Quick Reply: differential problem for 1991 F-150
