Heater is stuck on Defrost - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-21-2012, 07:11 PM
Slingnsteel Slingnsteel is offline
Slingnsteel is starting off with a positive reputation.
My heater is stuck on the defrost mode. I checked the vacum lines, they are fine. I have a 3 prong sylinoid with two vacum line conectors which I replaced with a new one that is located next to the battery on the firewall. I have read it was supposed to engage to create vacume when I switched from different settings like floor to defrost. I never hear the sylinoid work. This same sylinoid is also supposed to engage my ESOF. The ESOF does not matter cause I have switched to manuel hubs. Any thoughts from the experts or ones gone down this same road.
SM
Old 11-21-2012, 07:24 PM
boj760 boj760 is offline
boj760 is starting off with a positive reputation.
Stuck defrost
Welcome, Slingnsteel!
I'm far from an expert, but from what I've read here trying to get my ride up to snuff (99 F250 SD 6.8L CC XLT 4x4) it does sound like there's a vacuum leak. When you said you checked the lines, did that include the ones for the ESOF you don't use anymore? If they were removed when you changed to manual hubs, could any plugs/new lines have come loose?
Like I said, I'm not an expert, just trying to help.
Old 11-21-2012, 08:37 PM
Chad149's Avatar
Chad149 Chad149 is offline
Deplorable
Chad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputation
I s there vaccumn available at the soliniod or climate controls? What engine do you have? Depending on the year the diesels have an electric vaccum pump on the right fender underhood that fails occasionally.
Old 11-21-2012, 08:46 PM
I have a 99 250 SD V10. I also have a skipping issue at random times. Mostly when I am at low rpm's. I am gonna go through all vacuum lines.
SM
Old 11-22-2012, 02:59 PM
TravisG's Avatar
TravisG TravisG is offline
TravisG is starting off with a positive reputation.
Random question but, does ur overdrive switch still work? I had a 96 tbird that i bumped my od button and the defrost would only turn on. Turned out to be a bad fuse... my fuse was the ACC fuse. Just a thought.
Old 11-22-2012, 04:07 PM
Od works fine.
SM
Old 11-22-2012, 04:10 PM
TravisG's Avatar
Quote:
Originally Posted by Slingnsteel View Post
Od works fine.
SM
Dang. Thought i had it pegged. Lol id still check fuses. Crazy what all they can control off different fuses.
Old 11-22-2012, 10:08 PM
SC_Hoaty's Avatar
SC_Hoaty SC_Hoaty is offline
SC Chapter LDR
SC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputation
Sounds like lack of vacuum. If the lines that ran to the ESOF are just cut, they may be leaking all your vacuum. Also, some of the plastic tubing that is used can get brittle with age.
Old 11-23-2012, 08:06 AM
99powerstrokedF250 99powerstrokedF250 is offline
99powerstrokedF250 is starting off with a positive reputation.
Guys...not sure this is vacuum related. My 2003 has been switched to manual hubs, and the vacuum lines are not plugged, and my heat/ac controls all work fine. My father in law's 99 has ESOF with NO lines or plugs, and his heat/ac controls all work fine. If I recall, the defrost/floor/dash door is actually electrically controlled and there is an electric servomotor on the heater box under the dash that controls it. I know for sure that is how the temperature is controlled, because I had to replace it on my old 99. So you may want to look into that.
Old 11-23-2012, 09:58 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
The Super Duty ventilation system runs off of vacuum. When there is not enough vacuum to run the system, it defaults to blowing out of the defroster vents. This is done for safety.
So yes, it is a vacuum leak.
Old 11-27-2012, 09:14 AM
I checked my vacum lines, they are fine. The vacume for this truck is held in a canister behind the battery passenger side. I believe the vacume is created with a sylinoid on the firewall next to the battery. I also believe this same sylinoid engages the auto hubs for the ESOF. It is a new sylinoid and does not make a peep. The sylinoid on the transfer case that engages the 4x4 is an aftermarket. Would that have anything to do with the sylinoid on the firewall not responding.
SM
Old 11-27-2012, 09:33 AM
PSDInterceptor's Avatar
PSDInterceptor PSDInterceptor is offline
PSDInterceptor is starting off with a positive reputation.
Isn't vacuum created by the V10 engine's intake manifold
and stored in the canister?
A PowerStroke's vacuum is created by a Delphi vacuum pump.
Old 11-27-2012, 10:54 AM
I think the canister has several compartments for different things like engine, ESOF and heat controls. The problem I have is the vacum sylinoid that controls ESOF and heater does nt work.
SM
Old 11-30-2012, 10:55 PM
I found a link that I hope will help me figure out my solinoid problem. Here is the link
http://www.justanswer.com/uploads/mu...20056_1123.pdf
Old 12-01-2012, 06:27 AM
WTG, a Ford tech pub flow chart.
Repaired a Jeep Wrangler for a friend one time.
Battery acid had dissolved the 4x4 vacuum hub
hard line tubing. Put in a couple thick walled rubber
tubing splices, the dealer wanted over $300 to
fix it, I did it for free.
1976 Highboy Tank77 1973 - 1979 F-100 & Larger F-Series Trucks 16 06-05-2015 12:06 PM
A/C switches to defrost when 4X4 is engaged, ESOF 2005 F250 lakewood 1999 to 2016 Super Duty 2 04-13-2015 08:52 PM
AC Vacum Leak? dcara 1999 - 2003 7.3L Power Stroke Diesel 14 08-20-2012 01:51 PM
2006 F350 4x4 and A/C / defrost issues i eat hybrids 1999 to 2016 Super Duty 22 09-10-2011 07:33 PM
Vacum line diagram rdweathers 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-13-2010 06:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
