04 expedition air suspension issues
Hello everyone, I was wondering if anybody had this issue with their 04 EB edition expedition. My check air suspension msg came on, my air suspension does nothing. I took it to the ford dealer to pull codes. Codes C1760 - air suspension height sensor(rear), C1830 - compressor relay failure, C1881 - air suspension RF height sensor. I have jump the posts on the relay and the compressor runs. I have replaced the compressor relay & nothing happens still. I had replaced the RF height sensor so I know thats not bad. I just replaced the rear height sensor and still nothing happens. The dealer though it could be the 4wd module. They wanted $800 to replace the module & rear sensor so has anybody replace their 4wd module before? If I buy one I will still have to take my expo to the dealer to set the trim levels right?
M. Summers
M. Summers
If i replace the air suspension module myself will it need programmed? I want to make sure if I spend the money to replace the module & do it myself I dont have to do anything else special. Is it simply take out the old module, plug in the new one and the air suspension is back to normal? I dont want to have to take it back to the ford dealer if I dont have to.
beegeezee103
1997-2006 Expedition & Navigator
11-02-2006 12:28 PM
