7.3L Diesel Problems - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-21-2012, 05:51 PM
Reconor's Avatar
Reconor Reconor is offline
Reconor is starting off with a positive reputation.
Exclamation 7.3L Diesel Problems
I have a 96 F350 with the 7.3L Powerstroke. Its starting to act up and i need to get it fixed as soon as possible but i dont know where to start. When under load, or just cruising, it almost seems to backfire. It sputters for a second, then since its in gear starts right back up again and blows white for a split second. It almost seems like im out of fuel or water in my fuel but no lights light up or anything. Its a really quick buck or jerk and shakes the whole truck. Like the engine was shut off and then starts right back up within a second. Ive tried draining the fuel bowl and replacing every filter and nothing seems to help. I drive it 250 miles a day at 85mph most of the way. I keep it steady at 3000 rpm. Sometimes it just shuts off completely and i have to pull over and spend 5 minutes cranking for it to start. Is this a fuel delivery problem, or something else? Thanks in advance
Old 11-21-2012, 06:45 PM
427 fordman's Avatar
427 fordman 427 fordman is online now
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
You ever changed the cps?
Old 11-21-2012, 06:55 PM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
Dang at I thought that 65 at 1700 rpms was pushing it pretty good. I really don't like to drive fast.
My thoughts are CPS, or IDM.
Old 11-21-2012, 06:57 PM
That is running it PLENTY hard for sure.
Old 11-21-2012, 08:07 PM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
My truck started to cut out and buck befor and it turned out to be the fpr screen was all really dirty.
Old 11-21-2012, 09:19 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Sounds like the CPS.
Old 11-21-2012, 09:40 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Another vote for CPS. Shift into overdrive, why the 3K rpm's?
Old 11-21-2012, 09:49 PM
BuckHammer's Avatar
BuckHammer BuckHammer is offline
BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.
Quote:
No kidding.
Old 11-21-2012, 09:51 PM
Chris56ford's Avatar
Chris56ford Chris56ford is offline
lost
Chris56ford is gaining momentum as a positive member of FTE.
Sounds like the CPS. With 4.10s and the ZF, I'm about 3k rpms in OD at 85. The CPS will be the least of worries when grandma pulls out in front of you at 85 mph.....
Old 11-21-2012, 10:36 PM
baker1983's Avatar
baker1983 baker1983 is offline
baker1983 is starting off with a positive reputation.
My truck acted that way and it was cps buy only ford or international ones tho and my daughter called me grandpa cause my truck rarely sees 65 in a 70
Old 11-21-2012, 11:26 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Sound like CPS
85 + 3k = **** poor mpg's
Quote:
Smart man. I had to run mine at 72 in eastern washington, because the speed was like 70 or 75 and people were doing 80 or 85. Way too damn fast for me. I just don't even feel comfortable going that fast.
Old 11-21-2012, 11:34 PM
baker1983's Avatar
Quote:
When I first got my truck I drove it 70 and learned real quick that my fuel went bye bye at that speed and these things r tanks you hit someone doing 70-80 they aren't going to stand much of a chance as well as myself if I had a front tire blow out at that speed. It's funny Im a 29 yr old getting passed by elderly people going faster then me and they just stare
Old 11-21-2012, 11:44 PM
Yeah exactly. Even with 4 wheel discs these things are hard to stop. Mine even more as I have a flatbed that weighs an additional 1k, and a bumper that weighs 200+. It makes you a better driver though.
Old 11-21-2012, 11:56 PM
madpogue madpogue is online now
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
You need 3.55s.
Truck Starts, then dies: Also dies while driving RedDevil460 1999 - 2003 7.3L Power Stroke Diesel 9 08-12-2016 07:07 AM
Starting problems 95 7.3 Welchs_Grape 1994.5 - 1997 7.3L Power Stroke Diesel 41 09-15-2015 07:57 AM
Loss of power, give it fuel but no response Greenqueenf250 1994.5 - 1997 7.3L Power Stroke Diesel 7 07-05-2015 11:36 PM
2001 7.3L having 'chugging' problems 7.3 Pain 1999 - 2003 7.3L Power Stroke Diesel 3 08-16-2013 04:48 PM
1992 7.3 IDI hard starting when HOT carnagez28 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 08-05-2006 07:31 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
