7.3L Diesel Problems
Old 11-21-2012, 04:47 PM
Reconor's Avatar
Reconor
Reconor is offline
Exclamation 7.3L Diesel Problems
I have a 96 F350 with the 7.3L Powerstroke. Its starting to act up and i need to get it fixed as soon as possible but i dont know where to start. When under load, or just cruising, it almost seems to backfire. It sputters for a second, then since its in gear starts right back up again and blows white for a split second. It almost seems like im out of fuel or water in my fuel but no lights light up or anything. Its a really quick buck or jerk and shakes the whole truck. Like the engine was shut off and then starts right back up within a second. Ive tried draining the fuel bowl and replacing every filter and nothing seems to help. I drive it 250 miles a day at 85mph most of the way. I keep it steady at 3000 rpm. Sometimes it just shuts off completely and i have to pull over and spend 5 minutes cranking for it to start. Is this a fuel delivery problem, or something else? Thanks in advance
Old 11-21-2012, 05:19 PM
bashby's Avatar
bashby
bashby is offline
Camshaft sensor will do that.
Old 11-21-2012, 05:33 PM
Reconor's Avatar
Reconor
Reconor is offline
ive heard that before but i thought if that went out that the truck wouldnt run at all? is that correct?
Old 11-21-2012, 07:19 PM
bashby's Avatar
bashby
bashby is offline
Sometimes, My dad's 96 PSD was doing exactly what yours is. Research all pointed to cam sensor as being the most common cause. It fixed his. They are easy to replace and not too expensive.
Old 11-21-2012, 11:03 PM
Reconor's Avatar
Reconor
Reconor is offline
Ok thank you very much. Got one tonight for 22.12 and going to change it tomorrow.
Old 11-22-2012, 12:50 AM
Spktyr's Avatar
Spktyr
Spktyr is offline
Make sure it's a real Motorcraft or International one, the aftermarket or third party sensors for this application are crap.
Old 11-22-2012, 06:56 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Agreeded. Alot of the aftermarket ones will will not even start when installed or will last a week
Afrost
1999 to 2016 Super Duty
08-06-2018 11:09 AM
bike_guy123
28
09-03-2014 09:12 PM
Reconor
30
11-24-2012 09:46 PM
IdahoCowboy
22
08-19-2004 02:27 PM
jfonod
03-04-2004 04:40 PM
Quick Reply: 7.3L Diesel Problems
