Turbo rebuild ?s
I'll check back in tomorrow and if you can't get it figured out I will send you my phone number and see if I can walk you through it that way too.
Well I got it off yesterday! Used a socket on the turbine end and held the collar with a pair of vise grips. Turned it slowly with the socket and it loosened up without too much effort. Wondering if I should take the turbine/shaft to a machine shop to make sure it is not bent in any way before putting the whole thing back together?
spdmpo
11-21-2010 02:29 PM
