Fuel system diagram - Ford Truck Enthusiasts Forums
Fuel system diagram
Old 11-21-2012, 04:14 PM
johnsonswamp's Avatar
johnsonswamp johnsonswamp is offline
johnsonswamp is starting off with a positive reputation.
Fuel system diagram
Does anyone have a diagram of the fuel system from the filter up for a 95 f-150 4.9? Working on an old project that is missing everything from the filter to engine.
Old 11-21-2012, 04:47 PM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
The only thing between the fuel filter and the fuel rail (manifold) is one fuel line (hose).
Old 11-21-2012, 05:35 PM
So there is no external regulator? What about a fuel return line? It's been years since I've looked under the hood of this truck, so I don't remember squat from where I left off.
Old 11-21-2012, 09:06 PM
subford's Avatar
Yes there is an fuel pressure regulator mounted on the fuel rail and it has a return fuel line back to the tank. But it is not connected in the fuel line from the fuel filter to the fuel rail.
Old 11-21-2012, 09:28 PM
Thanks, that is everything I needed. Now to track down some lines since they have the fittings.
Wiring diagram airborne0130 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 02-25-2015 05:53 PM
88 f150 fuel system diagram? js2743 1987 - 1996 F150 & Larger F-Series Trucks 3 06-19-2014 05:16 PM
Please help need Fuel system Diagram and Vaccum diagram bb010864 1966 - 1977 Early Broncos 4 10-07-2010 08:41 AM
95 7.3 fuel system diagram?? also truck won't start. rigoberto 1994.5 - 1997 7.3L Power Stroke Diesel 6 04-10-2009 10:51 AM
Fuse Box Diagram rseghesio 1997-2006 Expedition & Navigator 2 07-14-2005 01:21 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
